whats the stock gear ratio on v6?
Old 07-16-2006, 01:02 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
I have a 91 RS 3.1 auto.
Im willing to upgrade my rearend gears
to higher ratio maybe 3.73 or 3.43.
now what im not sure is what would i have as a stock? 2.73?
all I know is its never been swapped,
and I dont want to open it up until i actually have it swapped by a shop..
is this upgrade possible without getting a whole new rearend?
or is there some upgrade gears for our stock rearend?
in advance for any info I reallty want to know what gear ratio im running.(and yes i searched and couldnt find it)
Old 07-16-2006, 01:05 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
https://www.thirdgen.org/1991-chevy-camaro
Old 07-16-2006, 01:16 AM
sogabe's Avatar
Engine: 3.1L
aww i guess i didnt have to search the forum.. lol
thanks!!
so if its a 3.23 already.. will 3.73 make lot of difference in acceleration?
Old 07-16-2006, 10:59 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
thanks!!
You bet it will .especially off the line ..will suffer on top end though..if you drive on them CAL freeways a lot I wouldnt go over that 3.73 gear..fuel mileage will also suffer some.It all depends on where and how you drive your car.I was considering a 3.42 but doing 80 MPH at 2000-2500 is awesome,probably just stick with what I have.
Old 07-17-2006, 01:47 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
you can check the rpo codes in the glove box for the axle ratio
Old 07-17-2006, 09:49 AM
daves12secV6's Avatar
i went from the 3:42's to 4:56's and it made a huge difference,except i do alot of driving so my gas milage was suffering alot.since then ive switched to 4:10's and gas milage is pretty good as long as u dont drive liek a manic,cruising @ 65 im just over 2,400 rpms
Old 07-17-2006, 03:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, I did a smaller jump than Dave did... I went from a 3.42 open rear to a 3.73 posi rear- WOW, what a difference! Even nicer since I had the special B&M 4-3 kickdown sleeve in my transmission... I could really pull strong in overdrive on the highway.
If you search this forum for posts by me (TomP) and the words "3.73", I think I had posted my RPM changes. I don't quite remember (that was back in 2001 or something like that!) but it was only an extra 200-400 RPM at 60 MPH.
So if you go from 3.23 to 3.73, yes you'll notice a BIG difference- and yes you'll use more gas.
Old 07-17-2006, 04:47 PM
3:23 to 3:42 = 190 rpm increase
3:23 to 3:73 = 500 rpm increase
3:23 to 4:10 = 870 rpm increase
3:23 to 4:56 = 1330 rpm increase
Old 07-18-2006, 02:10 AM
sogabe's Avatar
Engine: 3.1L
is the gas mileage loss very noticable?
caz i dont run tracks,
and i just want to have my car a bit faster
on off-the-line so that when im taking off the red light
im not behind all the stock looking honda cars
i know swapping ring/pinion isnt a easy DIY, so ill have a shop do it for me
but as for recalibrating speedometer is that a easy task?
thanks for any info in adnvace
Old 07-18-2006, 08:15 AM
if u go with 3:73's u will notice a good diff in acceleration.gas milage wont be that big of a idfference depending on how u drive.u have a 91 which has a electronic speed sensor so im not sure what u would have to do to calibrate the speedo with th enew gears.with a non vss car alls u have to do is swap out the speedo gears in the transmission
oh btw expect to pay around 600+ for a reputable rear end shop to install a new ring and pinion.parts are about 300 and genrally the labor for setting up a rear is about 300+
Old 07-19-2006, 08:28 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Mine is a 91 and all you have to do is swap the speedo gears in the tranny, still. I went from 3.23s to 3.73s...pretty nice improvement. My mileage still isnt bad either...with lots of engine mods, I still get 16 or so city and 25-26 hwy. I had 4.10s in it for a while but I felt that they were too much for it and the 1/4 mile.
Old 07-20-2006, 03:02 PM
stoned_pimp420's Avatar
Car: 1990 Buick Century (pimped out
Engine: 3300
Transmission: 4 spd auto
Axle/Gears: ??????????
And I ask this.....WHAT GLOVE BOX?????????
Old 07-20-2006, 04:32 PM
sogabe's Avatar
Engine: 3.1L
thanks for all the info guys.
just flipping around summit catalog i thought i seen ring and pinion for maybe
180$ or so.. but i could be wrong.
and is 300$ labor including all the flushing and refilling of the gear fluid too?
o well ill get a quote on that.. thanks!
Old 07-20-2006, 05:46 PM
buy all the parts urself and u will save money.gearsets run 160-200 from summit
and u also need a install kit(i.e bearings and seals) also 80-115 from summit.2 quarts of gear oil like 3-6$ a quart,th3 300 for labor is just an estimate.my shop charges 350$'s labor to set up a rear + cost of parts/oil etc
Old 07-21-2006, 12:57 AM
sogabe's Avatar
Engine: 3.1L
thanks for the info dave,
is that 350bux including the speedo recalibration?
caz i do not know what it takes to calibrate my speedo
after changing gears.. as mine is 91 and it's electrical speedo or something..
Old 07-21-2006, 04:37 AM
Xophertony's Avatar
Car: 1988 Trans-Am GTA
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
i know with the firebird electronic speedos there are gears in the trannsmission that need to be changed. these gears drive a cable on the old mechanical ones, and turn a censory wheel inside the VSS on the electronic ones. once you change these gears in your tranny your cars speedo will act as though it was in a car originally equiped with X.xx gear ratio.
Reddeath210
10-06-2015 08:20 AM
hectre13
08-26-2015 08:17 AM
Zeek1041
Theoretical and Street Racing
08-21-2015 08:45 PM
happyhapka
08-15-2015 04:42 PM
Quick Reply: whats the stock gear ratio on v6?
