Heater Core bypass
Old 07-13-2006, 03:33 AM
Stephen's Avatar
Car: 87 GTA
Heater Core bypass
I couldn't find a tech on doing this anywhere on the 'net.
My heater core just blew, and I'd like to bypass it until
I can get the core replaced.
I'm working on my 87 GTA, and this is my only car, so I need the core bypassed for now.
HELP!!!
Old 07-13-2006, 07:32 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
??? Disconnect both hoses at the firewall and connect them together with a hose connector and two clamps.
Old 07-13-2006, 09:15 AM
Stephen's Avatar
Car: 87 GTA
That would work...If I could even SEE the firewall. There's so much crap in the way...If I could the other ends of those two hoses, I could do that.
__________________
Stephen Cranford
'87 GTA
L98/TH700R4/BW 9-bolt 3.23
White w/tan interior
Previous Vehicles:
TGO.org co-founder
'97 Tahoe Solid black w/WS6 Ram Air hood/Impala SS wheels 4"/6" drop
'90 RS Radar Blue (purple)w/ Prowler Yellow stripes - Texas Spokes Sports Car Club Street Mod #12 (my #)/ Street Mod #42 (wife's #)
'92 RS Radar Blue (purple)w/ White stripes
"I don't suffer from my insanity...I enjoy every minute of it!"
Old 07-13-2006, 10:09 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Yes. There is a lot of crap in the way. Just like any other car. On mine the rubber heater hose comes from the passenger side of the front of the motor directly from the water pump, extends to under the a/c accumulator where it goes into the heater valve, then into a metal pipe that leads to the heater core. The other side of the heater core pipes go into the valve, then back around to the block.
If you HAVE a heater diverter valve, you should be able to unplug the valves vacuum line and plug both the valve (just in case) and the vacuum line.
If you don't have the heater valve (not sure what year they went in), then you must bypass.
Just like 8492 said, its just plumbing. Get 'er out of there and get the hose on both ends of it! 'fraid to get your skirt dirty?
Old 07-13-2006, 12:00 PM
Stephen's Avatar
Car: 87 GTA
Try permenantly disabled, and unable to physically do much, even with my one good hand.
Think before you speak...
__________________
Stephen Cranford
'87 GTA
Previous Vehicles:
TGO.org co-founder
Old 07-13-2006, 12:07 PM
Stephen's Avatar
Car: 87 GTA
BTW, I thought of the diverter valve idea. But, since there is that metal "T" connection on the passenger side down low, the water pressure would still reach the heater core, and leak. Same thing as the diverter valve being closed with the heat off.
I need to bypass the heater core completely. I thought about it going to bed last night, and I think I have it figured out.
One hose-to-hose connection.
__________________
Stephen Cranford
'87 GTA
Previous Vehicles:
TGO.org co-founder
Old 07-15-2006, 05:03 PM
bobdole369's Avatar
Car: 1989 Firebird
Isn't that what 8492 said above?
Old 07-15-2006, 05:08 PM
Stephen's Avatar
Car: 87 GTA
Yes...Kinda tryng to find another way.
We finally got it done, but must have bumped something. Now my car soun'm gonna search for a spark jumping somewhere. I don't see any loose plugs, so I'm hoping for an arc jumping that can be seen in the dark.
__________________
Stephen Cranford
'87 GTA
Previous Vehicles:
TGO.org co-founder
Old 07-16-2006, 02:47 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
soun'm ? and to me that sounded a lil disrespectfull
""Try permenantly disabled, and unable to physically do much, even with my one good hand.
Think before you speak..."" although i could be wrong and you could be some stuck up female teenager, but it sure in the heck sounds like it
the dude was just givin ya helpfull advice, plus it was not like you mentioned you were hadicaped in the begining anyway!!!
Old 07-16-2006, 02:53 PM
Stephen's Avatar
Car: 87 GTA
I don't advertise, nor make excuses for being handicapped. That would be a cop out.
His comment might have been meant as a joke, but people should consider, there may be a reason, before making wise-*** cracks.
__________________
Stephen Cranford
'87 GTA
Previous Vehicles:
TGO.org co-founder
Old 07-16-2006, 02:59 PM
Stephen's Avatar
Car: 87 GTA
You're right..."Stephen" sure sounds like a female name, huh? Whatever...
So I made a typo....Not like it even makes sense, or could be misread.
As a FOUNDER of this website, I seriously doubt I'm a even a teenager, much less female.
__________________
Stephen Cranford
'87 GTA
Previous Vehicles:
TGO.org co-founder
Old 07-16-2006, 11:05 PM
ChrisColeman's Avatar
Run a hose from the back of the intake manifold to the Radiator.
V edit: you were bitching about not being able to do it. I suggested an easyway. What the hell did you do with the line out of the back of the intake.
Old 07-16-2006, 11:09 PM
Stephen's Avatar
Car: 87 GTA
Why? It's easier to just connect the two heater hoses to each other. All I had to do was buy a 5/8" to 3/4" hose connector.
It's done now. It was a very simple install.
I'll email the tech write up to the admins, since it wasn't listed on ANY site on the web.
Old 07-19-2006, 04:27 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
Stephen, just a question, but why did you get all upset about getting your skirt dirty? It was obviously a joke, so whats up? Nowhere on your profile does it say you are handicapped. Im sorry to hear that, but come on. You cant expect us to know that unless you tell us, and if you dont tell us, dont get upset if we make wisecracks. Heck I was about to say the exact thing!
So I guess think before you snap back.
Old 07-19-2006, 04:38 PM
Stephen's Avatar
Car: 87 GTA
Profiling myself as handicapped, is making excuses for my inabilities. I make no excuses, I deal with it.
Off camber jokes are not called for in life anywhere. Would you just start calling somebody you met in life, "Retarded", without being concerned for their feelings? No, you wouldn't. 'Net shouldn't be any different.
Old 07-19-2006, 05:05 PM
Car: 89 RS
Engine: 2.8
um... I dont think any one called you retarded. whatever, deal with it.
Old 07-19-2006, 08:42 PM
Stephen's Avatar
Car: 87 GTA
Can you read? Apparently not...
The QUESTION was...The same as making a smart-*** comment, would be the same as calling somebody retarded. A stupid, un-caring way to communicate.
Old 07-19-2006, 10:20 PM
Car: 89 RS
Engine: 2.8
and now you are doing the same by asking if I can read..... Wow. to sad.
Old 07-19-2006, 10:50 PM
Stephen's Avatar
Car: 87 GTA
No, the difference is, I could give a crap less what you think...
I fully said what I meant. You just weren't smart enough to read a post...Sucks to be you...
Boils down to one thing...
A negative statement shouldn't have been used as a joke.
Old 07-20-2006, 01:14 AM
Car: 89 RS
Engine: 2.8
Old 07-23-2006, 07:26 PM
gottfuel's Avatar
wow stephen are those tears bro? There is a diff .,in NET versus FACE to face,and,,,,ya know what dude lets just say your a unique person and i will for as long as your on this forum remember that,,,Now leave it at that,
Old 07-23-2006, 07:30 PM
Stephen's Avatar
Car: 87 GTA
Why should I drop it now?
I did on the last post, but you had to come in and dig it up...You were never involved, nor should be now.
Old 07-23-2006, 09:15 PM
Car: 89 RS
Engine: 2.8
$750 L98
11-07-2015 02:26 PM
ndndndnd
09-28-2015 08:00 AM
Quick Reply: Heater Core bypass
