Defeat VATS Without Modifying PROM?
Old 01-12-2001, 03:45 PM
87/88Firetruck's Avatar
Apparently, most people who do not wish to deal with the GM VATS have all the VATS-associated equipment on the vehicle, and the greatest challenge is finding a resistor which matches the one in the original key. Unfortunately, I do not have such luxuries. I am trying to get around a 1986 'vette VATS, and all I have is ECM 1227165 and the original PROM. I found somewhere that a 50hz signal is emitted on the ignition circuit by the VATS decoder module, and that this can be created using an oscillator. Does this seem plausible to anyone? I am not having problems with the starter, since that circuit is independent, but the injectors on my system shut off after about 2 seconds and the ECM stores code 46. Any ideas on how I can get around this? My installation is from a 1987 L98 GTA, and I am using it in a 1988 GMC 1/2 ton truck. If the Passkey systems from 1986-1989 are similar, any reasonably simple means of defeating VATS would be useful, since this would enable me to use any MAF ECM. Thanks.
Old 01-12-2001, 04:18 PM
Blade's Avatar
Burn another chip with the VATS disabled. Simple as that...
Old 01-13-2001, 02:19 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
33-66 50%DC 5v signal
Double the speed and use a flip flop to get the 50% DC
555 running off a 7805 (?) it's a little 3 pin voltage regulator. Use a 10 Mfd cap on the Input side to the 555.
Old 01-13-2001, 02:58 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Permenantly Ground the relay.....
Old 04-24-2011, 02:54 PM
garvinshawn92's Avatar
Re: Defeat VATS Without Modifying PROM?
how do or what to do by grounding relay permanately
Old 04-24-2011, 02:58 PM
im having the same problem with the code 46 everything work except injectors arent feeding the fuel really aggrevating beings my car is stuck in front of gmas house and people have been trying to break in to it really sux
Old 04-25-2011, 09:28 PM
DENN_SHAH's Avatar
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
odds are the VATS wiring going to the key lock cylinder are bad near the lock cylinder. its a very common problem with the VATS.
if that is in fact your problem, you can replace the lock cylinder and get 2 new ignition keys to match the resistor of your old keys but cut for the new cylinder.
or you can build a bypass harness to bypass the lock cylinder.
you can get or build a bypass module that would make the ECM think the VATS system is working, but you would also have to bypass the starter relay.
you can have the VATS removed from the chip by burning a new chip with VATS disabled, again you would also have to bypass the starter relay.
if you do decide to replace the lock cylinder, be certain to buy a Delco lock
cylinder. the aftermarket lock cylinders are trouble prone and won't last like they should. where i used to work at, we tried the aftermarket cylinders a few times and always had to replace them within a few months with Delco lock cylinders and keys.
2 good pages of VATS info and trouble shooting,
https://www.thirdgen.org/vats
https://www.thirdgen.org/vats_passkey_system
hectre13
Car Audio
26
03-03-2022 05:38 PM
Linson
09-25-2021 07:55 PM
InfernalVortex
04-20-2021 11:31 AM
RS Reaper
10-17-2018 07:52 PM
Gunner242
12-25-2015 04:49 PM
Quick Reply: Defeat VATS Without Modifying PROM?
