??Connector terminal for 1227727 ECM connector??
Old 06-06-2006, 04:39 PM
kevosiroc's Avatar
Where can I get a connector terminal for 1227727 ECM.
I want to put my wideband O2 sensor into the MAP(2) input for the 8D_WB hac. I need to know where to find the terminal (and its' p/n)
Can anyone help??
Old 06-06-2006, 07:22 PM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
C21
According tot he pinout conversion that was on Ludis' website
Old 06-06-2006, 09:37 PM
JP86SS's Avatar
Some old info I found on the DIY-EFI site a while back.
Code:
Some GM part numbers:
If you're building/repairing a harness for the 1227165/727/730/749/808/747 ecms,
 you'll need 12047946 and 12045575.
 For 3 connector ECMs you'll also want 12089591.
 These are "car side" ECM connectors.
 Crimp terminals for the above are 12089660.
The connector inside a 747/808/148 ECM is Packard #12020756.
The yellow connector on a 730/749 is 12048046
Old 06-07-2006, 03:48 PM
kevosiroc's Avatar
Code:
Some GM part numbers: If you're building/repairing a harness for the 1227165/727/730/749/808/747 ecms, you'll need 12047946 and 12045575. For 3 connector ECMs you'll also want 12089591. These are "car side" ECM connectors. Crimp terminals for the above are 12089660. The connector inside a 747/808/148 ECM is Packard #12020756. The yellow connector on a 730/749 is 12048046
I did not think the terminals would be the same for the 7730 and the 7727 b/c the 7727 is an underhood ECM exposed to the harsh engine compartment environment. So doing extensive research (hours of searching around on www.delphisecure2.com), I was able to locate the p/n's I was looking for.... and then some. So here is what I found out:
12066132 - terminals
12052924 - seals for the terminals (package of 20 p/n 12048086 seals)
12065877 - Connector 'C' (Green on my Vette)
12065878 - Connector 'D' (brown on my Vette)
12065876 - Connector 'B' (Red on my Vette)
12065875 - Connector 'A' (yellow on my Vette - manual says Yellow or Gray)
12059155 - Header for connectors 'A' and 'B' (header is what is attached to the ECM and what the connector mates to)
12059154 - Header for connectors 'C' and 'D'
I think the connectors and headers are discontinued.
Old 06-07-2006, 03:59 PM
kevosiroc's Avatar
Code:
Not only did I look up the p/n's for the terminals...... I compared the p/n the connector drawing called out witht p/n 12089660 (that the DIY-EFI site references)
I found the terminals are not the same length for starters, and the dimensions and shapes are just a bit different. I do not know if the are interchangeable, so since p/n 12066132 is available, I will try that one.
Maybe this info should be catalogged somewhere????
Attached are the drawings
File Type: pdf
File Type: pdf
Old 06-07-2006, 05:10 PM
JP86SS's Avatar
[quote=kevosiroc]Maybe this info should be catalogged somewhere????/quote]
I saved it for future reference, nice work
Old 06-07-2006, 06:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I stickied this thread. At a later point I'll merge it into the DIY_PROM Guide book.
Thanks for the info,
BobR.
Old 06-08-2006, 08:24 AM
kevosiroc's Avatar
BobR.
Glad I could help!
Old 06-08-2006, 12:36 PM
kevosiroc's Avatar
To add another piece of info.....
I was looking for this info so I could utilize the 8D wideband hac.
These are the pinouts needed for the 1227727 ECM:
C21 = MAP(2)
C18 = TPS(2)
I have all the documents to back this up, but they are too large to attach
Old 06-08-2006, 08:36 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
Sorry: Repost
Old 06-13-2006, 03:46 PM
justa4's Avatar
I have the terminals available... still on the reels for use on assembly lines.
Drop me a note off list and I can send you some.
Old 02-16-2008, 08:31 PM
dariojuan67's Avatar
Re: ??Connector terminal for 1227727 ECM connector??
Hello friend,i have a 1984 corvette crossfire and need to identify the pinouts for the stock ecm #1226430 and reconect them to the ecm#1227747,so that i can use this newer ecm,i'll apreciate your help,i need to install this ecm in my crossfire,thanks alot,if there's anything that i could do for your just leet me know,thanks a lot.
Old 02-18-2008, 06:30 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by dariojuan67
Hello friend,i have a 1984 corvette crossfire and need to identify the pinouts for the stock ecm #1226430 .
Might help
Vette
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
747
http://www.chevythunder.com/1227747_ecm_198892.htm
Old 02-18-2008, 01:33 PM
oldred95's Avatar
www.eficonnection.com should have what you need. He is a member on here. S10Wildside is his name.
Old 05-19-2008, 10:05 AM
xtremesunfire's Avatar
sorry for bringing this back up but I just need to know what part number this is off the ecu I have pics of that yellow connector and the ecu is 1227730 and it came out of a 92 beretta gt 3.1.
and inside it say E1 to 16
and the wire diagram I got from the dealership is saying that is post to be green can somebody clear that up also. thanks
Old 10-29-2008, 10:37 AM
topacho's Avatar
any diagram conecction for connector M from ECM 96417551 XAHD DELPHI MR140 ?
the connection diagram it's neccesary for this problem:
Old 01-14-2017, 12:59 AM
edolin's Avatar
Hi! I'm Ed. I have been lurking on this website for a few years. I have 2 projects underway: an '86 Camaro / 350 tpi and a '50 Chev PU that will have a 383 tpi. Life has been getting in the way of completing these projects, but I now have some time. I am in need of enough 1227727 crimp terminals to wire 2 ecm's (plus a few mistakes). If you have any available, I'd be severely in your debt. Thanks in advance for any help. Ed (pedolin@msn.com)
Old 01-14-2017, 01:03 AM
edolin's Avatar
sorry, posted wrong.
Old 01-14-2017, 11:29 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I have some pigtails for the 727 ecm and a good used complete harness . I think the terminals have been discontinued.
Old 01-15-2017, 11:47 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
For the crimp terminals what I do is identify the terminal I need usually by looking here:
http://ecat.delphi.com/
note the part number and then look here to buy:
Waytekwire.com
They also have the proper crimp tool at waytek for only something like $22.00.
I usually buy bags of 50 or 100 of the terminals I need.
Old 12-12-2019, 09:44 AM
ChevyGearHead84's Avatar
I know this thread has been dead for almost 2 years but I came across it while looking for parts/info to rewire my project. I know there are some harness wiring geniuses out there that know the answers.
All of the Delphi pages listed are inactive so they are no help. I am wondering if anyone has found new sources for the ECU connectors, terminals, seals and such. I have tried google searching the part numbers listed with little to no success. I have even been searching for used terminals and or harnesses with little to no luck. So if no one has the terminal info but has the 4 connectors for the 727 ECU with all the wires/terminals still in them (wires cut long enough they can be soldered) I would be interested in those.
I know it is going to be a long shot but I am going to call a chevy dealer today and see if they can help out, if they can I will update
Old 12-12-2019, 10:51 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Almost anyone should be able to get a cut harness with the connectors and terminals. I should have something for you now if you want to send me a PM
F.I. 57 Belair
08-23-2021 01:09 AM
gta892000
08-11-2019 11:16 AM
eustodp
09-20-2015 05:09 PM
Chevy86 IROC-Z
09-07-2015 01:13 AM
middian
09-05-2015 01:42 AM
Quick Reply: ??Connector terminal for 1227727 ECM connector??
