How to connect 2 seperate 0 gauge wires together....
Old 06-06-2006, 01:21 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Just like the title says. I am currently running a 0 gauge power wire, but am reconfiguring my amplifier and crossover locations so I need to lengthen the wire a bit. I still have about 4 or 5 feet of 0 gauge wire, and want to use something to connect them. Imagine taking a fuse holder, but eliminating the fuse so that you could connect the two wires together. Anyone see anything like that? Any information would be greatly appreciated. Thanks, Paul Moore
Old 06-06-2006, 01:33 PM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
when it gets to that size they have to be bolted together, they can be soldered but u would need a mini tourch or somthing thats gonna get it hot enough
the fuse hold sounds good but the wouldnt be a bad idea to use a fuse in it a a precaution
Old 06-06-2006, 02:08 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Take the two wires ends and smach em together. Then twist to it looks like one wire. I usually wrap mechanics wire around it to hold it in place. Then take a torch and some soldering wire and get to work. The only problem is that the solder likes to drip off the wire. Try and keep her under 400 degrees. Also, use good heat shrink, the kind with the adhesive. Even if your soldering is shotty, that heatshrink is enough to hold her in place.
Old 06-07-2006, 10:14 AM
drlivingston's Avatar
Just get you and ANL fuse holder, attach 1/0 gauge to each end, and put a 300A ANL fuse in it. That will give you your connection without worry of a blown fuse.
Last edited by drlivingston; 06-07-2006 at 10:15 AM. Reason: forgot to add signature
Old 06-07-2006, 11:36 AM
paulmoore's Avatar
Well, that is what I was thinking, but I already have a 300A ANL fuse in my main fuse block by the battery. I guess it really doesn't matter seeing as how no one will see the second one.
Old 06-07-2006, 12:44 PM
It's just for a connection not really a safety measure. If you are competing, noone will really care about the additional fuse if it can't be seen.
Old 06-07-2006, 07:40 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
They make 0 gauge wire connectors. I have one in my car. You put both ends in each side and turn a allen head bolt on each side to clamp down on the wire. Stinger made mine and I bought it from sounddomain.com
Old 06-08-2006, 04:12 PM
Birdman92's Avatar
Car: '92 Firebird
Engine: V6 for now
What he said
Old 06-09-2006, 02:26 AM
paulmoore's Avatar
Do you have the URL for that page so that I can see it? Thanks!
Old 10-29-2023, 11:49 AM
BassBtch93's Avatar
Re: How to connect 2 seperate 0 gauge wires together....
so zero guage HAS to be solderd? No strip and twist?
Jeremys87
07-14-2022 09:08 PM
rocn7roc
09-21-2021 02:16 PM
BRoss99
12-07-2020 06:50 PM
Jk_Under
08-17-2015 03:08 PM
Quick Reply: How to connect 2 seperate 0 gauge wires together....
