Cigarette Lighter Won't Stay In Now....Why?
Old 05-18-2006, 09:03 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Well I've had the cigarette lighter out of my car for a good 6 or 7 years now since my radar detector was plugged in there. I also use it for my power inverter when I datalog. I hardwired in my radar detector yesterday and when I went to reinstall the lighter it was loose in the recepticle and wouldn't stay in at all. Is it possible that the larger plugs from the radar detector and power inverter bent something inside there so it won't stay in now? If so which part is bent? A pic would be very helpful if possible.
Old 05-18-2006, 11:18 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
i have the same problem on my car too. i just wrapped tape around it to keep it tighter since i dont use it.
Old 05-18-2006, 12:14 PM
Car: 89 IROC-Z
Engine: 383
Thanks, not exactly the fix I was looking for though.
Old 05-18-2006, 07:00 PM
Car: 89 IROC-Z
Engine: 383
Ok got it straightened out. Here's the fix for the rest of you. Pull the fuse for the accessories or disconnect the battery. About 3/4" into the recepticle there are 2 tabs that face backward into the dash. If you use a pick or a small screwdriver you can bend these back into the opening. This snugged it right up.....5 minute fix.
Old 05-19-2006, 08:56 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Thanks for that. I was just wondering the same thing for my car.
bbsr72
04-02-2016 09:12 AM
bigjay89gta
10-15-2015 08:04 AM
Agent507943
Firebirds Wanted
10-02-2015 07:18 AM
SS-EXPRESS
09-28-2015 09:14 AM
Fronzizzle
09-08-2015 12:10 PM
Quick Reply: Cigarette Lighter Won't Stay In Now....Why?
