Pro comp Aluminum heads
Old 04-19-2006, 02:33 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Just found these heads for sale thu ebay.
Fast Engine Parts
looks like a good buy tho the manifacturer "pro comp electronics"
isnt reasuring me ..
Any thoughts ?
Old 04-20-2006, 02:59 AM
Spectre's Avatar
Engine: 3.0L/183
PROCOMP ELECTRONICS
They seem to have a lot to offer, just cant find positif feedback regarding
there products ..
Old 04-20-2006, 07:51 AM
shaggy56's Avatar
Car: 71 Nova
Axle/Gears: 8.2 posi 3.08
Im pretty sure those heads are made in China and are a poor copy of edelbrock heads. Superflow is the other name they go by.
http://www.fordmuscle.com/archives/2...EditorsCorner/
Why dont you look into the RHS heads? They are proven heads with good quality and affordable.
Old 04-20-2006, 11:33 AM
Shagwell's Avatar
Car: projects.......
They look kinda like my Pro Tpolines(now RHS) especially with the "...raised runner...only fits Victor/Hurricane manifold..." in the write-up. But, thats from looking at a small pic and write-up, so I'd just go w/ the RHS, about the same money anyhow.....
Old 02-13-2007, 02:01 PM
WakkoWarner's Avatar
Pro Comp Heads......
I e-mailed them this morning & those heads are manufactured in Australia. So, I would be willing to bet that they are just fine.
Old 02-13-2007, 02:10 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Id spend the extra $150 for piece of mind alone and get Trickflows or Brodix heads. Remember, there's more to heads than just flow: its cast quality, and also component quality. Besides, who do you think you are more likely to have good customer service with, a reputable company, or a knock off no name brand?
Old 02-13-2007, 02:55 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
ProComp Aluminum Heads
I bought a set of vortec aluminum heads made by ProComp. They've got 190cc runners, 2.02"intake and 1.60" exhaust. I purchased them from my local hot rod shop. I know the owner and he's built a sub 9 second car so I know he knows his stuff. Whatever says he I listen. He hasn't steered me wrong yet and they are a really nice set of heads.
Gene
Old 02-14-2007, 03:21 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Here is my Opinion well, it isn't really an opinion because I own one of the products.
I own the Procomp MSD knock-off distributor. Its a peice of ****. Every single one of the terminals on the cap pulled out of the cap itself when pulling wires off, the ignition module crapped out within a few months so it wouldnt start occasionally and i'm getting a oily residue inside of the cap itself which can't be good. Oil isn't very conductive if at all.
If this is an indication of the quality of other Pro-Comp products, i'd stay away. Expecially when its something like cylinder heads that could cause major damage.
I'm not the only one with a problem with their distributors either.
Old 02-14-2007, 03:41 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
im going to be runnig there 190cc intake heads on my 355, ive seen them in person they are a great looking head!, quality looks top notch, and both the guy at the local speed shop and my engine buidler have had nothing but good things to say about them, look at the numbers they flow great and you cant beat the price
Old 02-16-2007, 08:21 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
a friend of mine has them on his blazer they are the 215 fully cnc ported one, we had no problems at all with them. They work great. at 600 they flow 306 which is real good. On the blazer with a 355 and them heads it ran 10.25 @ 134 all over the track and lifting 3 times on a 175 horse kit. and it weighs 3250 and it's areodinamicly challenged!
Old 05-17-2007, 01:12 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Pro comp Aluminum heads
I am also running the 190cc procomp aluminum heads and agree that they are very nice quality heads for the money.
Old 05-17-2007, 03:15 PM
shaggy56's Avatar
Car: 71 Nova
Hey when you guys put some miles on those heads report back. I seen some stuff about the heads having problems later down the line. But hey if they work good who knows.
Old 06-01-2007, 08:38 PM
tommyboy's Avatar
Car: 87 Formula
Transmission: TH400
Axle/Gears: 5.00
DO NOT BUY PRO-COMP HEADS !!!!!
I helped a friend assemble a 351 Windsor and when it came to the point to check the piston to valve clearance, the rocker arm tip to the valve was off.
The tip was more towards the intake side of the valve all the way through the rotation. At first it seemed to be a push rod lenght issue, then we realized that the stud bosses were off about .100 thousands towards the intake side. There is no cheap way to fix this issue. We sent the heads back for a set of Edelbrock Victor JR's and the problem was solved. Another situation was with a friend that purchased a victor sbc knock off intake. The ports were hammered in the intake and had casting flash that was epoxied, that was almost falling off. Their Quality is horrible, so buy at your own risk..... Their parts are not associated with Pro-Action or RHS in any way.
Old 12-27-2007, 08:07 PM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Anyone else? Any updates? Thanks
Old 12-27-2007, 08:32 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Ihave the 190cc 64cc angle plug heads. I have no cvomplaints at all so far.
Old 12-28-2007, 05:15 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Found this: http://www.boatstoreonline.com/procomp.html
Old 12-28-2007, 11:33 AM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
That boatstore article is BS, Ive got a set on my 383 and I couldnt ask for a better running motor. Granted as stated above the older ford castings required offset rockers, but I sell over 100 sets of SBC heads a month with 0 problems. Also I sell alot of the SBF, BBC, and Iron Chrysler magum heads with 0 problems as well. For the money you cant go wrong. Just buy them bare and assemble with quality components. It seems like the only people with problems are buying all of the older castings that are selling on ebay or have been sitting on a shelf for a long time. If anyone would like to see pics of mine I will be happy to send them to you just drop me a PM
Seth
Old 12-28-2007, 01:26 PM
81caballero's Avatar
I have seen 2 different sets up here in canada....1 from a retailer, and bought off of ebay. there was a difference in dech thickness and rough casting marks. the newer ones were better quality. some guys on www.maliburacing.com didnt like them when they tried them. But i think for the most part its going to depend on what your upgrading from.....stock gm old iron, or going from a set of dart iron eagles.
Old 12-28-2007, 03:41 PM
galvarado's Avatar
Car: 88 Camaro SC
I'm using a set of ProComp aluminum Vortecs in a 383 build. It's gone well so far. I have yet to start the engine, the swap is in progress.
Old 12-28-2007, 04:18 PM
3rdgenmaro's Avatar
Car: 88 IROC
Transmission: 700 r4
I know a guy that is running a set on a mild 350 in a 72 Nova. He likes them. I bought a set of Dart's new platinum pro1 heads fully assembled and shipped for $1065. Just a thought.
Old 01-13-2008, 08:21 PM
cdwood388's Avatar
Here's my opinion, There is no better head than what you are willing to spend. Personally i bought The AFR Race heads and they ran me right at 1550 will springs for a solid roller cam. Either these or Dart pro 1 aluminum were my two choices. The flow numbers on either of these two surpasses the pro comp i see advertised. The AFR and Dart only differ a little in the cc i got afr 210 and i think the darts are 215. How much power do you want. I am shooting for around six hundred, from what i read the pro comp are good for 500 or so.
Old 02-19-2008, 09:57 PM
wakeborda's Avatar
Hey there from Australia. Just to clear up myth and dispel the illusion that Aussie manufacturing is garbage, PROCOMP cylinder heads ARE NOT made in Australia. They are marketed here and unfortunately many people believe them to made here, tarnishing our reputation for great and innovative engineering.
I believe that great RHS heads are manufactured in Townsville, Queensland, Australia. I have a PROCOMP coil in cap "HEI" dizzy (came with it unfortunately) on my ski boat and its just as bigger piece of garbage as the rest of their stuff. We keep melting the guts of it out. Several local hotrodders have been bitten by the same problem, getting 50 klicks down the road and breaking down! We're putting a Mallory on soon.
PROCOMP SUCKS.
Hope this helps.
Small Block forever!
Old 02-19-2008, 11:46 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Their electronics might be bad. Never bought any of it. But, I have a set of Pro Comp 210 cc heads that I bought bare. I'm going to do my own porting. I also have a set of Dart 200 cc Iron eagles, and a set of Dart 215 Iron Eagles. The Pro Comp heads have a much nicer casting. Didn't take near as much porting to get them ready to go. I did however get one with a raised valve guide. I sent it back and got a replacement. I have started the setup on the springs ect. All of the installed hights were with in .002. That's pretty darned good. They do need a little work to make them a very good head. I'll do a little work for $900.00. They could have been run right out of the box with an intake match on a street car. Don't knock sh-t unless you have had first hand experiance with it.
Old 02-19-2008, 11:53 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Just to be clear, this Procomp isnt the same one that makes all the 4 wheeling tires?? Is it?
Old 02-23-2008, 09:51 PM
peanutmrpeanut's Avatar
I have just got done putting these heads on my camaro with tpi on it. These heads do seem ok but there is some work involved. Iused a 15 thousands head gasket. Stock push rod length seemed ok to me and some of the thins I had to do to get these work was I had to use a 1985 intake from a tpi car and I had to drimmel bottom spring retainer thing or what I think is called to cup. not much but just enought to be able to get the socket on the head bolt. Other than that they seem to be working good I had a set of vortec 194's on there before. and I have notice a great deal of a power increase over them. The heads I went with are the 2.02 1.60 vale 190cc on a 64cc combustion chamber. Thanks
Old 02-24-2008, 01:39 PM
offshore's Avatar
Seth
The article is not BS, IT IS true 100%!!! The heads suck! In fact I just dumped 3 sets on ebay http://cgi.ebay.com/ebaymotors/ws/eB...m=330208692604
They look great, but when you put them on the dyno
P.S. You will drive yourself crazy when you CC the runners and chambers on these heads too. Even the CNC heads are so far off you'll be questioning yourself, but don't worry it's not you or the equipment, IT'S THE HEADS!!
Old 04-24-2008, 03:44 PM
ted850's Avatar
ok,I bought a set of pro comp 3003a,sbc heads bare for a spec sprint car motor.I took them to my machinist,he was sufficently impressed,so he back cut some valves and set the heads up for my application[1.46 dual springs,good retainers ect.].The only issue was I had to clearance the combustion chamber for the 13/1 Ross pistons I used .No big deal 1.5 hr with a die grinder.[I dought flat top pistons would have been a problem] Ran the motor hard 2 mains so far ,good power,no problems.these heads aren't full blown racing heads, but are a great 'bang for the Buck'
Old 04-24-2008, 10:51 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
http://cgi.ebay.com/ebaymotors/PATRI...mZ270230852682
these are patriots at a decent price. a name u can depend on at least too!
Old 04-28-2008, 09:31 PM
1QWIKZ's Avatar
Car: 88 Camaro
Transmission: TH-350
Has anybody been to the track since putting these heads on? If so any improvement over your previous heads or what?
Old 04-28-2008, 11:43 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
i just bought a set of the 190cc/64. iam very happy with the way they look. the spring shims got in my way to thou. the casting was very clean. and the combustion chambers were just as nice as any other(non cnc'd) head ive seen. we had stock L98s on it before. as soon as its up and running ill tell you if i've seen any power increases. but if these head make more power than the vortec heads, then i KNOW ill be impressed.
Old 04-29-2008, 10:39 AM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
after my initial post,the only prob i had was 1 mounting bolt hole was misdrilled. The top one next to the manifold,for the serp bracket... Im gonna run this sunday at the track ill post my times.
Old 04-29-2008, 11:05 AM
1QWIKZ's Avatar
Car: 88 Camaro
Cool, what heads did you replace?
Thanks Jim
Old 04-29-2008, 11:29 AM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
came as a crate package. but in all fairness I have been looking at the AFR eliminators or the Patriot Super streets.
Old 05-01-2008, 08:24 PM
1QWIKZ's Avatar
Car: 88 Camaro
Did you ever baseline the motor when it was in crate motor form?
Old 05-02-2008, 05:15 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
no.ran out of time.
Old 05-06-2008, 11:10 AM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
ok. I ran it sunday..I made alot of mistakes and mishaps. buthere is the best run of the day.
r/t .192 (caught napping)
60 1.725
330 4.979
1/8 7.649
mph 90.09
1000 9.939
1/4 11.883
mph 116.58
...w/ 100shot of nitrous...and maybe the meth injection (the ind. light never came on)
i made 6 passes total. not counting the first one. I snapped the throttle linkage off the carb at the line . My last pass was 12.07 117.30
Old 05-07-2008, 06:43 PM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
that run was on a 100 shot? I ran faster than that with my stock ported l98 heads that have bigger valves in them on a 383. I just went to afr eliminators to replace the ported stock and had concidered the procomps or patroits. Glad I went afr after seeing that. If any one needs a good set of proven heads my old ported l98s are for sale. Only reason I changed is to go with a larger custom 80cc chamber to lower compression to 9 to1 for a turbo. My heads are completey proven with very low miles and better parts for less money. ready to go.800 obo..
Old 05-07-2008, 10:05 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
I wouldnt trounce a product because of my rookie times. Hell I can put my grandma in a vette, but that doesnt mean all vettes run 25s in the1/4 I agree that you should go for the best head you can afford. But at the time, I could be driving the car,or sit in it making motor noises and dreaming how fast it will be when I can get the better heads.
Old 05-08-2008, 09:30 AM
lt1z350's Avatar
my car bone stock with a 125 shot went 113 and I was no pro when I did it. Didnt spray it until second gear too. I am just saying that I would guess that your car would go 106 to 107 on all motor and my 92 formula did that with bolt ons. With a lt1 cam and ported stock 113 with stock valves went 112. Now with the new valves and comp cam broke 118. I have seen the patriots dynoed(which are better) pick up 22rwhp over stock l98 heads.Changed out for afr 190s the old design and picked up 65 hp. 22 hp is not worth 800 bucks. I would compare my heads to afr 180s and worth 800 bucks.These companies look at a head and try to copy it. That is like saying that just hogging out a set of heads will make more power. You can ruin the design and kill a head if you dont know what you are doing. especially if you butcher the short side. If you cant afford a good set get a good used set. Heads are not a place to cut corners. I am not trying to knock your car but I am sure it would be way faster with a name brand head.
Old 05-08-2008, 10:48 AM
boost v 8's Avatar
Car: firebird
Engine: small one
Transmission: 2 speed
Axle/Gears: 360 gear
nice
Old 05-08-2008, 12:43 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
I agree completely. Im looking into the afr eliminators now. I got what i was looking for at the time, and now its time to improve it. Hopefully if everything goes as planned.
Old 05-08-2008, 01:25 PM
lt1z350's Avatar
You will be in for a pleasant surprise depending on how big the cam is I would say upwards of 60 more rwhp. I got mine at tre performance. Have them in stock and very fast to ship also the best price around. got mine for 1525 with titanuim hardware shipped to my door. pn 1038 which are larger 75cc chambers. You will be very happy with the pick up. Will run what it does now on the spray with just motor depending on cam and intake. Well worth it .
Old 06-13-2008, 02:43 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Anyone know anything about Procomp's cranks and rods?
Old 06-13-2008, 07:10 PM
Tony_B972's Avatar
Car: 86 IROC
Engine: 383 (in progress)
Transmission: tko 600
Anybody know anything about their valve covers, i can't help being a little tempted to get em for the price for fabricated
Old 06-13-2008, 09:26 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i dont see a problem with the valve covers but i surely wouldnt buy their crank and rods.
Old 06-18-2008, 02:45 AM
I bought some fabricated covers off of ebay. When they came and saw they were pro comp I knew they would be **** after my experience with the pro comp distributor I had.
My assumption was correct. The flanges were warped from the welding so they leaked. You could actually rock them when you set them on something flat, like a table. LOL
Junk.
Old 06-18-2008, 03:31 PM
Tony_B972's Avatar
Car: 86 IROC
well cheap or not garbage is garbage and that old saying usauly holds true u get what u pay for so i guess im spendin the $ on the quality ones,
thanks 4 the heads up
Old 07-12-2008, 09:02 PM
1QWIKZ's Avatar
Car: 88 Camaro
Well, I finally made a pass with my pro comp heads and I was expecting the worse but I was actually surprised.....1st pass was a 12.2 then the 2nd was 12.1 and it needs some tuning which I knew it would.. Also, it was pretty damn hot I might add!!!!!!! But all in all I am happy especially for what I paid for them and it also put to rest some of the rumors for me anyway..
Old 07-13-2008, 10:43 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
1QWIKZ you say you're using 200cc iron eagles in your profile... ?
Old 07-14-2008, 04:18 AM
1QWIKZ's Avatar
Car: 88 Camaro
I have to change it...They were my old heads because I had an incident last yr...
Quick Reply: Pro comp Aluminum heads
