Parts for Sale 2006 Keep it Third Gen related please!
Crane Energizer 10052 CamShaft + Lifters
Old 03-29-2006, 05:13 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
up for abid is a crane energizer camshaft + lifters + LUBE. this setup has less then 500 miles on it, reason for selling, i upgraded to a bigger camshaft. They are in great shape and seriously look brand new. All lifters are in order, you can click the thumbnail at the bottom to see the full picture. These sell for 119.95$ US new, so throw me an offer.
Part Number: 10052
Grind Number: 272 H10
Engine Identifications
Start Year - 1957
End Year - 1987
Make - Chevrolet
Cyl - 8
Engine Make - 262-400 C.I.
Description - Good Idle, Daily Usage, Off Road, Highway Towing, Fuel Efficient. Performance, 2600-3000 Cruise RPM, 8.75 to 10.0 Compression Advised. (50 State Legal, Pre-Computer, C.A.R.B E.O D-225-21 Basic RPM 2000-5000)
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @ Cam 3027 @Valve 454
Exhaust @ Cam 3027 @Valve 454
Rocker Arm Ratio 1.5
Cam Timing: Tappet @.004
Lift: Opens Closes ADV Duration
Intake 27 BTDC 65 ABDC 272 Deg
Exhaust 67 BBDC 25 ATDC 272 Deg
Spring Requirements: Triple Dual Outer Inner
Part Number 99848
Loads Closed 114 LBS @ 1.700 or 1 45/64
Open 303 LBS @ 1.270
Cam Timing: TAPPET @ .050
Lift: Open Closes Max Lift Duration
Intake 3 BTDC 33 ABDC 105 216 Deg
Exhaust 43 BBDC (7) BTDC 115 216 Deg
Minimum RPM 1600
Maximum RPM 5400
Valve Float 5600
Attached Thumbnails Crane Energizer 10052 CamShaft + Lifters-crane100528ab.jpg
roughskinjrz is offline
Old 03-29-2006, 05:20 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
$55 shipped to 87108?
wesilva is offline
Old 03-29-2006, 05:26 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
new mexico? shipping is 30$ alone. i can do 70$ goin there. canada, ill do 60$ shipped.
Old 03-30-2006, 11:22 AM
wesilva's Avatar
Transmission: 200R4
Last I checked New Mexico was part of the lower 48 states. You know....New Mexico...part of the United States of America? Without New Mexico, you would be making a $60 offer to the lower 47.$60 then........?
wesilva is offline
Old 03-30-2006, 11:51 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
sorry, when i checked shipping for other parts of the united states it was 10-15$ cheaper then where you are.
ill do 65$ to you.
Old 03-30-2006, 12:08 PM
wesilva's Avatar
Transmission: 200R4
PayPal, Money Order.....? How would you like to be paid?
wesilva is offline
Old 03-30-2006, 12:55 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
clintsgoods@rogers.com = paypal
wanna give me your address also, just to confirm the one with paypal.
Old 03-30-2006, 02:38 PM
wesilva's Avatar
Transmission: 200R4
PMed ya.
wesilva is offline
Old 03-31-2006, 07:11 PM
wesilva's Avatar
Transmission: 200R4
PayPal sent. Thanks for your patients.
wesilva is offline
Hotrodboba400
12-10-2019 07:07 PM
skinny z
10-05-2015 06:23 PM
TexasMaro
09-15-2015 06:50 PM
dimented24x7
09-06-2015 03:51 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Crane Energizer 10052 CamShaft + Lifters
