KYB GR2 vs Gas-a-just
Old 03-22-2006, 04:46 PM
91black5spd's Avatar
Car: 1991 Pontiac Firebird
Transmission: 5 speed Manual
Just wondering what the difference is between these. I was going to get the GR2 front struts and I am deciding between the Gas-a-just and GR2 rear shocks. I figure since I am getting the GR2s up front and they dont make the gas a just struts I would get GR2s in the rear so I have matched front and rear struts/shocks. However I see that a lot of people get the GR2 front and GAJ rears. The price difference isn't that much but I thoughtit might be better to use the same line of KYBS all around.
Old 03-22-2006, 08:55 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I say get the same all around. Not very sure about the differences though.
Old 03-22-2006, 08:58 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Double post, sorry
Old 03-23-2006, 01:28 AM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
I have cars equipped with stock struts, on with Bilsteins and one with KYB.
If I ever buy another set it will be Bilstein or equivelant +.
It mya be hard to swallow the dollars now, but your ride and your butt will enjoy it alot more.
There is no comparison.
later
Jeremy
Old 04-20-2006, 07:54 PM
LB87FORMULA's Avatar
Car: 87 Pontiac Formula
Engine: 5.7L Crate Engine
Transmission: 5spd NWC
I guess nobody answered your question...
I am also thinking about purchasing the KYB Gr-2 struts.
I'll probably call KYB tomorrow and ask them.
Old 04-21-2006, 03:26 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Gas-a-justs are a hi pressure monotube shock, like Bilstein. Most people go with the GR2 strut and gas-a-just rears. KYB does not make gas-a-just struts. As far as the shock, gas-a-justs are much better then GR2s.
Old 04-21-2006, 07:33 AM
I ended up using GR2 shocks and struts because I wanted to have the same type all around. I am happy with the results they gave the car a nice balance between ride and handling. Some people use the Gas-a-justs in the rear which might work better but I figured I would get the same struts/shocks all around.
Old 04-22-2006, 05:40 AM
Thanks for the info.
I didn't get a chance to call KYB, but I am probably
just go with GR2 all the way around.
Old 04-22-2006, 07:07 AM
DakotaSLT's Avatar
I don't know about the GR2's, but I know the Gas-a-Just's carry a lifetime warranty, and are mono-tube vs. the GR2's twin tube design. I have GasaJusts on my autox car, and my roomate has GR2s on his Focus, I know that's not comparing thirdgen to thirdgen, but the Gas-a-Just seems to be a much higher quality piece to me.
Old 04-22-2006, 09:14 AM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
I have GR2 all the way around. They are no way as good as Koni or Bilstein.
But for the money a good deal.
customblackbird
08-15-2021 10:16 PM
loud91rs
10-05-2015 10:05 PM
tcflint
09-27-2015 05:58 PM
87camaro87
09-09-2015 10:29 PM
Quick Reply: KYB GR2 vs Gas-a-just
