How can I match my Vin, Enigne and Transmission Number
Old 02-28-2006, 06:48 AM
On Probation
Joker's Avatar
Car: 87 Pont Firebird
Engine: 305 Carb
I'm trying to find out if the numbers all match on my 87 Pont Firebird. Where can I go to entry my VIN Number and see what my engine and transmission codes where when it was built?
Thanks,
Old 02-28-2006, 07:32 AM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The number on the engine is easy.
If you remove your Alt (on the Front RH side) there is a Hog that sticks out on the BLOCK. There you can find a bunch of numbers, the last 5 will be the sequence number which would match the last digits of your VIN.
What you want to look at is the lower smaller numbers.
Here you will see it as 2HN211943,
IIRC
2 = Pontiac
H = 1987
N = Norwood
2 = Pontiac
11943 - Sequence number
Attached Thumbnails How can I match my Vin, Enigne and Transmission Number-engine-tag.jpg
Old 03-01-2006, 06:43 AM
On Probation
Joker's Avatar
Engine: 305 Carb
Yes, I totally understand locations of the ID's. My question is how do you find the numbers (not on the vehicle) on record for when the car was purchased.
Old 03-01-2006, 07:34 AM
okfoz's Avatar
Are you talking about the RPO sheet??? Its a decal that should be located in your center console. It is a list of 3 digit codes, like CC1 for T-tops, MXO for Automatic Transmission, LG4 or LB8 or LB9 or L98 for the Engine etc.
If this is missing then your SOL, you can contact GM and have them make you a dealer invoice which would include most of the options, but thats $50, and most people are not interested in paying that kind of cash.
Your Vin will indicate the engine that originally came in the car, IE, the 8th digit will have an F, H, S or 8, the F = LB9, H=LG4, S=LB8 and 8 = L98, it will not however determine your original Transmission.
If you have a base firebird your vin will look like this:
1G2FS21??H?2?????
John
okfoz
Convertibles
83
10-29-2018 11:18 PM
Reddeath210
10-06-2015 08:20 AM
fasteddi
09-02-2015 10:29 AM
dbrochard
08-30-2015 05:56 PM
Armored91Camaro
08-25-2015 12:01 PM
Quick Reply: How can I match my Vin, Enigne and Transmission Number
