Using the wrong oil filter.
Old 02-03-2006, 10:36 PM
zrated57's Avatar
Will using the wrong size oil filter damage anything and can it cause the oil pressure gauge to read inaccurately? I was looking at Fram oil filters and bought one for a 1987 IROC Camaro with a 350. My car is a '85 with a 350, but of course, not stock in 1985. So I found out the block came from a 1981 C-10 truck. The original filter I purchased was smaller and I went back and got a filter for an '81 C-10 and it was the correct size. The reason I'm asking about the oil pressure is because my gauge is always maxed out when the engine is on, but when starting it it will go down to zero and right back up, so it's obviously getting a signal. My guess is that a smaller filter would increase pressure not descrease it, if it's affected at all.
Old 02-03-2006, 11:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Wont effect it. You could use the shorter one or longer one. Doesnt matter.
Old 02-04-2006, 12:40 AM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
as long as the threads are the same and the gasket seals you can use any one you want to.
Old 02-04-2006, 01:49 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Your first mistake was buying a Fram oil filter.
Old 02-04-2006, 01:54 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
Old 02-04-2006, 10:54 AM
stitchop's Avatar
Car: 91 firebird
FRAM
Years ago, before I knew better than to use a fram filter , I could barely reach the filter with an oil filter wrench. So the next time I bought a filter, I took the correct one out of the box and compared it to the bigger (longer) filters until I found one that had the same threads and top was the same. The PH 5 was about 2" longer and that is the size I use now.
Old 02-06-2006, 12:52 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I use a filter for a 454. I believe it's a PH-5. Works well. Gives you a little more capacity.
Old 02-06-2006, 01:33 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
if I don't use a k&n filter I use an AC Delco PF1218 or a PF454.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Hotrodboba400
12-10-2019 07:07 PM
gta892000
08-11-2019 11:16 AM
Dyno Don
01-24-2016 08:24 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Using the wrong oil filter.
