Has anyone tried the CAT RH-350B retrofit roller rockers?
Old 01-07-2006, 09:59 PM
fourtrax's Avatar
Has anyone tried the CAT LRH-350B retrofit roller LIFTERS?
As the topic says, has anyone tried these, or know if they are any good?
For $154.56 from pace, they sure are cheap.
http://www.paceparts.com/index.asp?P...&ProdID=147275
Edited for stupidity: these are lifters not rockers
Old 01-07-2006, 11:37 PM
ljnowell's Avatar
Wow. That would be incredibly cheap. I am ready to order some right now.
Old 01-08-2006, 12:22 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
never tried them or heard of them before....I'd be abit cauisous getting them, that price seems REALLY low, just keep in mind you get what you pay for.
Old 01-08-2006, 12:25 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Old 01-08-2006, 07:04 AM
fourtrax's Avatar
While they are tremendously cheaper than other retrofit kits, and I think we can assume where they are made, my question is this: should adding a bar to link two lifters together double, or even triple the price of the lifters alone?
Old 01-08-2006, 07:07 AM
fourtrax's Avatar
Yeah, somebody order a set and check them out.
Old 01-08-2006, 11:44 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
While we are on roller lifters does anyone have the part number for 16 factory lifters? I can find the part number for a single lifter 2nd design. I can find the part number for the kit which I don't need the extra pieces also 2nd design.
Old 01-08-2006, 06:00 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
If they last 100,000 miles order me a set.
Old 01-08-2006, 09:47 PM
ljnowell's Avatar
Someone has to try it. I will be going over my engine this spring so i may as well try it. At worst I will be doing it over again.
Old 01-09-2006, 01:24 PM
fourtrax's Avatar
Pace is out of stock of these for an indefinite period of time.
Apparently there is a supply problem. I was going to take a shot and see what they looked like.
Old 01-09-2006, 06:35 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
One time I was looking for product info on CAT stuff and I was given a number for one of their reps. When I tried talking to the guy he barely spoke english.
I started having flashbacks to the time I bought a Chinese screwdriver set and they looked nice, but the tips got chewed up after like 3 uses.
I still have them to this day. I use them for opening paint cans.
At least they were cheap.
I've decided that I'd let someone else be the guy who road tests CAT parts.
On a positive note, the stores that sell CAT rods and cranks say they have a good record. So apparently Chinese metallurgy has made some progress since I bought those screwdrivers.
But I'm still hesitant about things like roller bearings.
Some factory hyd roller lifters from Autocenter were $120/set, the last time I checked.
Old 01-09-2006, 06:55 PM
shaggy56's Avatar
Car: 71 Nova
Axle/Gears: 8.2 posi 3.08
Well then be worried because you may own a car or two with chinese parts in it already.
http://www.china.org.cn/english/BAT/121037.htm
Heres the kicker
GM expects to boost parts purchases in China to US$4 billion in 2009 from US$200 million in 2003, according to Merrill Lynch, while Ford expects annual purchases in China to reach US$6 billion by 2010, or 7-10 percent of its global requirements. Chinese exporters mainly make components for the aftermarket but are increasingly eager to enter into the higher-end original equipment-manufacturing (OEM) sector.
How are all those Eagle and Scat cranks and rods holding up since they are chinese too.
Old 01-09-2006, 10:50 PM
shaggy56's Avatar
Car: 71 Nova
You make a good point because they do sell oem lifters with the cross bar and they are nowhere near the price of retro lifters. Proves that this is just a way to market on something.
Old 02-05-2006, 04:14 AM
shaggy56's Avatar
Car: 71 Nova
These are on ebay. I didnt see any part # for the big block version like these in the Cat catalog. Funny because I have seen other manufactures sell retro roller lifters for both small block and big block with same dimensions. Im not to faniliar with big block lifter dimensions.
http://cgi.ebay.com/ebaymotors/Chevy...spagenameZWDVW
Old 02-06-2006, 06:59 AM
fourtrax's Avatar
I think what they're selling probably resembles the second picture, but it looks like they snatched that image from Summit, so who knows what the actual lifters they're selling look like.
Old 02-07-2006, 03:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Solid rollers for $100 ?! If they are any good, I might have to get a set!
Prodigious
Theoretical and Street Racing
35
04-13-2021 02:37 PM
TX-SleeperC5
02-24-2016 01:34 PM
skinny z
10-05-2015 06:23 PM
TX-SleeperC5
09-24-2015 03:13 PM
Billyadams
09-22-2015 08:25 AM
Quick Reply: Has anyone tried the CAT RH-350B retrofit roller rockers?
