NEW SB CHEVY PRO TOPLINE TORKER 167cc 64cc SBC HEADS
Old 01-05-2006, 03:16 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
This auction is for 1 set of BARE Pro Topline 167cc intake runner 64cc combustion chamber, 1.94/1.50 valve SBC IRON Chevy heads, these have a 64 cc combustion chambers and straight plugs, part # 2236494083. This auction is for 2 bare heads. These heads have a valve job from the factory and are ready to assemble!
We can provide all the parts to assemble these w/ stainless steel valves for a total of $519.00
thinking about putting these heads on my budget rebuild of an 87 l98 while i have the motor out of the car..
anyone run these or have pro ro cons with these heads?? its got the stock cam in case anyone wants to know ..
Old 01-08-2006, 08:49 PM
Shagwell's Avatar
Car: projects.......
I'm running the 200cc lightnings(aluminum). great heads. the torquers are more like World products torquers though. samller runner desgined to promote low-end grunt. Still a good head, and probably really good on a L98. I'd deffinitely look into some middle of the road "stage 2" porting. Stage 2 meaning bowls(if need, probably not on toplines) and gasket matching. - maybe raising the exhausts just a tad. - still great heads, especially for the $
Old 01-09-2006, 08:50 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Are your factory heads shot? I don't see the improvement worth the money after shipping and taxes (?). Take your heads to the local shop and have a three angle valve job, say $100 and clean up the ports yourself. If your heads are pretty much worn out these would probably be a good replacement head. Note they are for screw in studs and larger springs so your old hardware will not complete the bare heads.
Old 01-09-2006, 08:57 AM
bbtaz97's Avatar
Car: 91 RS
the factory heads have like 90 k on them so i mean i cna clean them up and have the tools to put new springs in and stuff but i wanted to compare these heads to the iron l98 heads i have as well as some other options out there.... dont want to spend tons on new heads but 500-600 would be doable....
wouldnt have to pay shipping on these the shop that sells them in like a 10 min drive form my work...
Old 01-09-2006, 12:44 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Took my heads off at about 125K miles to rework them some. They looked like new still, guides tight, valves and seats were perfect. Your heads should be the same. The L98 heads are known as pretty decent heads for stockers, about the same as the old 300HP 327 heads of yesterday. If it were me I'd look for some more up to date heads with Vortec chambers and ports, spend the extra money for the lower intake - or go with some aluminum heads and get the best of today's improvements. I looked around and decided to just redo my heads and hang on to the money. Not looking for all out performance anyway.
Old 01-09-2006, 01:46 PM
bbtaz97's Avatar
Car: 91 RS
well thanks tom3 for you imput... it pretty much what i was looking for in terms of opinoins... .. i mean i prob get some new seals , springs and even new manley vavles and clean things up alot and thyw would flow pretty good.. jsut didnt know anythign about these other heads..
thanks
midge54
12-27-2019 04:14 PM
Reddeath210
10-06-2015 08:20 AM
Mickeyruder
09-02-2015 02:45 PM
LT1Formula
08-20-2015 09:36 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: NEW SB CHEVY PRO TOPLINE TORKER 167cc 64cc SBC HEADS
