corvette 700r4????
Old 12-31-2005, 07:00 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
corvette 700r4????
Hey guys, i've already done a search and found nothing. I am swapping a 89 corvette 700r4 into my 87 iroc. everything is mounting up fine except one thing, the transmission cross member. Has anyone had this problem or done this swap and if so any pointers on what to do. Any help would be appriciated.
Old 12-31-2005, 09:32 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The factory fitted trans, in a c4 vette, does not have the mounting holes for a trans mount. It does not even have the boos in the case. Therefore you cannot drill and tap it. To my knowledge, it is not possible to bolt into a third gen.
Old 01-01-2006, 03:33 PM
phoenix305's Avatar
Well i guess i'll have to think something up on my own because everything bolts up just perfectly except that cross memeber, i just swapped a thirdgen tailhousing onto it and it went right in.
Old 01-01-2006, 03:40 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The output shaft is also 3/4 of an inch shorter. You may develop a vibration in the driveshaft.
Old 01-01-2006, 06:09 PM
phoenix305's Avatar
is there anyway to prevent that or remedy it?
Old 01-01-2006, 07:41 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
It may be fine. If not, the only way to fix the output shaft is to change it. This involves complete dissassembly of the trans to do it.
Old 01-01-2006, 09:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Also need to change the location of the speedo drive gear on the output shaft when switching to a 3rd gen tail housing.
RBob.
Old 12-22-2007, 07:11 PM
sps589's Avatar
Re: corvette 700r4????
I can make a bracket for the trans mount using your original tailshaft housing extension.
Old 12-23-2007, 01:16 AM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
I had a vette 700r4 in my z28 for a while. I did notice the tail shaft was shorter but I never had any vibration problems. To mount it I made a steel "L" bracket that bolted to the bottom two tailshaft housing bolts and I bolted the mount on the bottom of that bracket. Do you kinda get what I am saying?
loud91rs
10-05-2015 10:05 PM
92projectcamaro
09-29-2015 07:07 PM
IROC ZELLER
09-29-2015 03:00 PM
indygene
09-26-2015 11:21 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: corvette 700r4????
