Formula for Port/runner Cross section?
Car: '92 Corvette
Transmission: ZF6
Axle/Gears: 3.45
Is there a formula for figuring optimal port/runner cross sectional area, based on displacement and desired RPM? In other words, I know the bore and stroke. I know the RPM I want the engine to make max torque at. With that info, and I figure the best runner area?
Thanks.
-Tom
Thanks.
-Tom
I'm sure there has been an attempt at a formula of some sorts. I've never encountered one. To my simplistic way of thinking, it's as much an art as a science. The VE of any given engine will determine the volumetric needs, and that is affected by chamber design, valve position and design, valve timing, RPM, and various other factors including the intake design. Presuming a "perfect" intake, one might extract a given runner area (cross sectional) for a given pressure drop. Unfortunately, there are dynamic forces within the intake runners themselves which affect the overall flow. That was one of the original intents of the CFI (and TPI, and most other intakes).
As a result, both conventional fluid flow dynamics and sonic wave/pressure theories are involved. How they will overlap with any particular combination is your question. Search for theories about the "Mesh Method" as described by Roland Benson. His texts may have some helpful information.
One crude, incomplete formula is as follows: Peak torque rpm = (cross section area x 88200)/cylinder volume.
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
This is interesting reading, if nothing else.
http://www.circletrack.com/techartic...458/index.html
"Is there a relationship between plenum volume
and runner length or can runner length be changed
moderately without requiring a complementary
change to plenum volume?"
yes! IT CAN!
but theres other factors
your forgetting
port cross section
port taper
valve size
COMPRESSION,ratio
CAM TIMING,
EXHAUST SCAVAGING,
exhaust back-pressure
ROD LENGTH,
DISPLACEMENT
throttle body flow
ignition timing
bore to stroke ratio
intended rpm range
rear gear ratio
flame front
and a few more
http://victorylibrary.com/mopar/intake-tech-c.htm
http://victorylibrary.com/mopar/cam-tech-c.htm
http://www.rbracing-rsr.com/runnertorquecalc.html
http://www.bgsoflex.com/intakeln.html
http://headerdesign.com/extras/engin...take_Manifolds
http://www.digitalcorvettes.com/foru...light=designed
http://www.team-integra.net/sections...?ArticleID=466
http://turbonation.com/intake.htm
http://www.wallaceracing.com/runnertorquecalc.php
http://www.mercurycapri.com/technica...intake/pt.html
ever wonder WHY intakes are designed with runners shaped like they are?
you might want to read this info
yes! IT CAN!
your forgetting
port cross section
port taper
valve size
COMPRESSION,ratio
CAM TIMING,
EXHAUST SCAVAGING,
ROD LENGTH,
DISPLACEMENT
throttle body flow
ignition timing
intended rpm range
rear gear ratio
flame front
and a few more
