transmission wont hold gear
Old 12-04-2005, 10:48 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I just installed a new transmission today and I am having problems with it.
The transmission wont go into gear and when I do get it into gear it wont hold.
The TCI instructions said to put a quart into the converter (new TCI) and then 4 quarts into the trans.
Then start the car and fill the rest of the way with the back wheels off the ground.
I did this but the trans wouldent go into reverse or drive when I shifted there. I can give it a little gas and when I let off it goes into gear. but then when I shift to drive it just acts like its in neutral unless I do the gas thing.
What is wrong???
Its a turbo 350.
Thanks for any help.
Old 12-04-2005, 12:56 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Nevermind, Filled the trans all the way and now it works fine.
Old 12-04-2005, 08:31 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Done that a few times, though the trans was dead when it wouldnt go into gear and it just needed a quart or 2 of fluid
Old 12-04-2005, 11:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
A trans needs somehwere around 12+ quarts or so.
Its really bad for the clutches to not have enough fluid. Theyre only made of paper and glaze/burn real easy with slippage.
Old 12-08-2005, 04:05 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Well I filled it with enough fluid but now I have a different problem. The trans wont downshift into first gear when I come to a stop. when I step on the gas again it just stays in 2nd.
Sometimes just when I come to a complete stop it SLAMS into first.
Any ideas?
Old 12-12-2005, 07:29 PM
1988-305-tbi's Avatar
i'm kinda having a similiar prob. sometimes when i take off from a dead stop the torque converter stalls to 2k and feels bogged down and at 35 mph or so it shift to third. my trans is a rebuilt 700r4 from maddog transmissions. stay away from maddog trans he's a expert salesman not a expert trans builder.
Old 12-12-2005, 08:06 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Problem seems to have gotten beter since I adjusted the vac modulator. But I dont know why that would've helped.
Reddeath210
10-06-2015 08:20 AM
Dialed_In
08-20-2015 01:45 PM
mizz0313
08-12-2015 06:45 AM
Quick Reply: transmission wont hold gear
