Need help with Vortec 305 Heads
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
I'm thinking about getting some heads for my 305 and was wondering how the Vortec 305 heads were. The casting number I have found for them is 12552520. Anyone have specs on these? How good would they be on a stock 85 305 TPI? I'll more than likely throw a cam in there too while I have the engine broken down that far. Probably a XE262H or something like that. Thanks for the help
Kevin
Kevin
Yeah thats where I found the casting number but they have jack on info about em.
Kevin
Kevin
Car: 82 Z28
Engine: Al LT1 headed LG4 305
You don't want them, they are not like 350 vortec heads. Its not worth it.
Car: 1983 G20 Chevy
The 520s are different than the 350 castings, the 509s that came off the later Express vans are not. They are identical except the chamber is scaled down and the intake valve is .010" smaller. They still flow a paltry 235 CFM on the intake and identical to the 350 on the exhaust. They also have the kidney bean shaped chamber as well.
You have to remember the 305 vortec express make 235 FWHP and 290 ft/lbs of torque and that is with the MILD B-body LT1 cam. Had GM given it the F-body LT1 cam and a better intake/exhaust this engine would have easily made 310-320 ft/lbs and 260 FWHP.
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Originally posted by Fast355
The 520s are different than the 350 castings, the 509s that came off the later Express vans are not. ....
The differences, ALL the differences, among all the (Gen 1 type) Vortec heads would make an interested thread... especially if coupled with the iron and aluminum LT1 heads.
235 fwhp *(350/305) = 269 fwhp (which is very close to the 255 fwhp of the L31 Vortec, which used the Bcar cam)
IHI has flow data for the 305 Vortec heads, linked in this post. I don't remember them getting anywhere near 235 cfm. 199 cfm was the peak airflow that I recall.
thanks for the replies. basically, i checked out the post on the 305 vortec heads and decided that's not the way i wanna go. i think i'm gonne get the 062 castings, get the .020 milled off to clear the bore, and put them on my motor with the SD TPI intake. the 062 castings are fairly cheap and easy to find so hopefully this will be a good mod for not a whole lot of money.
By the way, how well does the stock 85 TPI cam work with these heads?
Kevin
Kevin
84z96L31vortec
08-20-2017 12:16 AM
Fast355
12-02-2016 06:33 PM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
