does a car over heat with too much antifreeze
Old 11-18-2001, 05:34 PM
killer305's Avatar
i had my car running for like 20 minutes today trying to get some of my other problems fixed and when i went to shut it off the temperwture was like 280* then it started to steam out of the middle of the radiator cap. then i looked at the overflow and it was almost full. i filled it with antifreeze yestarday, because it was filled with water, and i know i willed the overflow 2 much. there are 2 marks one says hot, one says cold, it was filled about 2 inches above hot when cold. i havent left it on for long since, i just hammered up and down my street and parked her. i swear to *** if this thing overheats on the way to work tomorow i will be pissed, i seized the engine in my winter beater friday due to the heater hose breaking, and me not looking at the gauges(gotta love fords) but tomorow ill definatly have my eye on the guages
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Old 11-18-2001, 07:29 PM
SSC
SSC's Avatar
Car: No more birdy
A healthy dose of pure antifreeze will not make your car overheat. It can raise the temprature up a bit but nothing dramatic.
It's possible that the thermostate is sticking. How do the cores in the radiator look, are they clean? Is there any water dripping out of the weep hole in the water pump? I would check these out and change the thermostate. If everthing checks out then its most likely a temprature sender problem.
Good Luck.
SSC
Old 11-18-2001, 07:32 PM
breathment's Avatar
well, 100% antifreeze wouldn't do to good in ur car and might cause it to get to hot, this due to the poor heat transfer of antifreeze compared to that of water. if i was you i would totaly flush out\clean ur coolent system. and depending on where u live, put in the correct amount of antifreeze\water. might wanna ask some other people around there.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old 11-18-2001, 08:15 PM
killer305's Avatar
no no water is comping out of the pump, im 99% sure its not the thermostate because it was fine with the water, i guess ill just drain a little more, and put some water in it, right now id say its about 95% antifreeze, it happened when i was tring to time the car, do you thing early setonation or something could cause exsesive heat. thanks
Old 11-18-2001, 08:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Agreed.
Antifreeze is just that "anti" freeze. It's an additive to keep your cooling system from freezing during the winter.
My race car currently has an antifreeze mixture in it for the winter. When spring arrives the antifreeze gets dumped and a mixture of water and waterwetter gets put in. Water is a better conductor of heat than any mixture of antifreeze.
With your temperature going that high there's a problem and it's not with the coolent strength. Thermostat stuck closed, water pump seized or belt broken, radiator plugged solid, are my guesses. One other thing to check is for a blown head gasket. Take off the rad cap. run the engine and look in the rad for bubbles. Engine compression can put excess heat in the cooling system. This is usually followed by rads and overflow bottles constantly pushing out the coolent.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old 11-18-2001, 08:22 PM
killer305's Avatar
we will see how it does tomorow. thanks
Old 11-19-2001, 01:19 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Also, pure anti-freeze will actually freeze! It must have water mixed with it to perform its function.
Weird, eh?
Old 11-19-2001, 02:48 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
the more antifreeze you use the lower the boiling point you get... a 50/50 mix and some water wetter is the best choice... if the car continues to run hot you need to track down watever other problems it has...
zroc
CRFred
02-07-2016 11:39 PM
mustangman65_79
09-01-2015 03:51 PM
TheExaminer
08-26-2015 04:59 PM
fonzie85
08-13-2015 11:50 AM
IROCThe5.7L
DIY PROM
08-10-2015 11:24 AM
Quick Reply: does a car over heat with too much antifreeze
