4.0 l jeep motor please tell me how to set the timing with out a light.
Old 11-11-2001, 11:15 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
What is the firing order? just in case I get a timming light what wire should I hook it to? and what should the timming be set at? And how do you ste it by ear exactly? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old 11-12-2001, 10:10 AM
Tas
Tas's Avatar
www.jeepsunlimited.com
www.off-road.com
www.pirate4x4.com/forum/
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old 11-12-2001, 05:22 PM
Tom 400 CFI's Avatar
Car: '92 Corvette
Transmission: ZF6
Axle/Gears: 3.45
You can't set or change the timing on a Cherokee 4.0 liter. The distributor does nothing but sent the spark to the proper cylinder. The actual timing is dictated by the ECM, which recieves it's signal from a cam and crank position sensor. Turning the distributor will just change how far the spark has to jump inside the cap to get from the rotor to a terminal on the cap.
I used to have one of those things. I hated it. I wanted to flip that thing sooo badly. Or centerpunch a phone pole. Anyway, I have a J-20 now. 401, D44/D60, T-18, NP 208. MUCH better.
[This message has been edited by Tom 400 CFI (edited November 12, 2001).]
Old 11-12-2001, 05:38 PM
thatsme's Avatar
The firing order for a late 70's 4.0 is
153624. It porbably hasn't changed since then. I don't know how it is with jeeps but with every other fuel injected motor i had you still had to set the base timing even if the ecm was controlling it. Hook the timing light up to #1 cylendar (its the one closest to the front. Your goint to have to find which wire to disconnect to bypas the ecm's controll of the spark b 4 you set the timing. Under the hood there should be an emission sticker to tell you what the base timing should be
[This message has been edited by thatsme (edited November 12, 2001).]
Old 11-12-2001, 06:02 PM
Car: '92 Corvette
Transmission: ZF6
Axle/Gears: 3.45
<font face="Verdana, Arial" size="2">Originally posted by thatsme:
I don't know how it is with jeeps but with every other fuel injected motor i had you still had to set the base timing even if the ecm was controlling it. </font>
That's because in some other FI engines, the DISTRIBUTOR is what generates the ignition signal AND distributes it to the proper cylinder. In the Jeep, there is a crank position sensor on the rear of the block, getting it's signal from reluctor wheel cast into the fly wheel. THAT generates the signal the ECM uses as basic information on spark timing. To alter the timing, you would need to either change the flywheel's position relative to the crank (tough to do!), or move the crank position sensor (also tough to do). Think of it like this; the crank paosition sensor does a similar function as the magnetic pickup in a conventional distributor. If you hook a timing light to the Jeep, and rotate the dist. while the engine is running, the timing will not change, because the timing signal does not originate from the distributor.
Old 11-12-2001, 08:28 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
What Tom said is correct.
The dist. on this type if ignition does nothing as far as actual timing is concerned.
Thats why these Jeeps take so long to start, they crank and crank till the oily/dirty crank sensor in the bellhousing figures out where #1 is.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old 11-13-2001, 10:24 AM
Car: '92 Corvette
Transmission: ZF6
Axle/Gears: 3.45
LOL Engineboy!
Chaaa-cha-cha-cha-cha-cha-cha spu-spu....roooooooooom!
It always killed me that a late model SFI engine took 7 times more cranks that the old two barrel 401 in my J-20. I knew why, but I thought it was another pathetic aspect of that fine vehicle...
Old 11-15-2001, 06:14 AM
BLACK Z's Avatar
Car: 86 Z28
so if the dist has been moved what should I do , where should I move it back to?
Old 11-15-2001, 07:50 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
If it has just been turned and not removed, look for a couple of punch marks on the dist base and block.
The fact. will sometimes mark them after assembly.
Not sure how to set it without looking at a manual (none here )...I've never tried to turn one....
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old 11-16-2001, 10:45 AM
BlackBird91's Avatar
I have a 92 jeep I put a long block in, after farting with it for 8 hours I did some heavy research. You need an old dist cap with the side of ti cut away around # 1 wire lead. find TDC for #1 cylinder by pulling the spark plug and ratating the engine till the cylinder produces pressure,set the timing mark on zero. Now with the rotor on and the dist. cap on you need to put the distributor in so the rotor is just comming up to the #1 tit on the cap. about .005" gap between the rotor and the tit on the cap. After I found out how I got it on the first try.40,000 miles later its still running great. good luck
91 Firebird TA
5.7 TPI
WS6 performance package
700 R4 W/O 3rd & 4th
soon to be replaced
Old 11-16-2001, 10:51 AM
fireing order 1-5-3-6-2-4
the rotor turns clockwise when standing at the front looking at the motor
Frozer!!!
01-19-2024 04:55 PM
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
Caspar
06-19-2016 11:19 PM
Andrew6.688
12-13-2015 10:59 AM
Thirim
08-09-2015 06:19 PM
Quick Reply: 4.0 l jeep motor please tell me how to set the timing with out a light.
