torque specifications for SBC with aluminum heads/intake
Old 09-06-2005, 11:48 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
hey i tried to look it up on the internet, and on this site, and didnt get much help.
i have a '72 350 4 bolt main with trick flow aluminum twisted wedge heads, and an edelbrock aluminum torker intake
what should i torque the heads to? and the intake?
also im using APR head studs
could i get a diagram of which sequence the studs should be tightened, and to which ft lbs.
also for the intake
please dont flame or write anything stupid, help would be greatly appreciated.
Old 09-06-2005, 12:04 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Here is the pic:
https://www.thirdgen.org/techbb2/sho...orque+sequence
Contact ARP for the correct torque.
For the intake, start in the center, and work your way out.
11 7 3 2 6 10
12 8 4 1 5 9
Those #'s represent the order to torque the bolts looking down from the top of the intake. Usually 25-30 ft-lbs.
Old 09-06-2005, 01:16 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Actually, it's a little different than that.
Sequence
12.....11......4......1......5......6
10......9.......3......2......7......8
Old 09-06-2005, 01:51 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
lo-tec was that sequence for the heads for aluminum or cast iron ones??
i heard different versions
60ft lbs for aluminum and 65ft lbs for cast iron
Old 09-06-2005, 02:13 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok so i call ARP and they said 65ft lbs with sbc and aluminum heads.
now im using just regular bolts for the intake, which of those 2 sequences above is right?
Old 09-06-2005, 02:48 PM
Lo-tec's Avatar
The sequence AJ_92RS posted is correct. Sorry for the misinformation, tried to remember it instead of looking in a book.
Old 09-06-2005, 04:07 PM
kevinc's Avatar
Car: 1982 Z28
Re: torque specifications for SBC with aluminum heads/intake
You mean, like misspelling "ARP"?
Old 09-06-2005, 08:42 PM
AJ_92RS's Avatar
Well, with rates on the move the way they are I can see why "APR" was on his mind.
Old 09-06-2005, 09:28 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
thanks, i got one head on, what a bitch.
the guidplates where the rocker studs are, what do they have to be torqued down to? i had to loosen one a little to torque a head stud, and i just tightened back up pretty good to, but im pretty sure it has to be torqued.
Old 09-07-2005, 12:22 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
For aluminum heads, torque them to 65ft-lbs in 3 even steps. I usually go 20-43ish-65. Haven't had a problem yet. This was also with ARP head bolts
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
deemoney
Theoretical and Street Racing
09-13-2015 07:02 PM
Ragtop Man
09-12-2015 12:23 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: torque specifications for SBC with aluminum heads/intake
