Best positive valve stem seals ???
Old 09-03-2005, 08:36 AM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
I'm wondering what kind of positive seals you guys are using.
On the intake and exhaust.
I know Fel-Pro SS72527 looks good for the intake valves but I can't find anything similar for the exhaust.
Any suggestion.
PAT
Old 09-03-2005, 09:23 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I dont know what part number i used, but i used two sets of intake seals, put intake seals on intake and exhaust.
Kevin
Old 09-03-2005, 06:51 PM
IRACE87's Avatar
Car: 1987 IROC-Z
How would the Fel-Pro Viton seals hold up on the exhaust ?? I wonder.....
It's hard to get good info on valves seals, it's not something that gives more HP so people don't really think about them that much.
PAT
Old 09-03-2005, 08:50 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Fel-Pro's level of quality for valve stem seals is always at least that of original equipment. Service life, not cost, dictates the materials required. Although seals made of premium materials, such as VITON® or polyacrylate, are much more expensive than seals made of nitrile, they represent but a small fraction of the total repair cost. Therefore, it just doesn't make good economic sense to sacrifice a long-lasting, successful repair to save on the cost of the valve stem seals. With Federal-Mogul's Fel-Pro valve stem seals, you'll do the job once, and do it right the first time.
That should help in your decision I think.
Old 09-04-2005, 06:58 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Use Fel-Pro SS72527 on both the intake and exhaust. They are positive type Viton.
Old 09-04-2005, 09:23 AM
IRACE87's Avatar
Car: 1987 IROC-Z
The Fel-Pro SS72527 are for the intake valves. Is it because of the material they are made of (heat resistance) or because of the amount of oil it will control ????
PAT
Old 09-04-2005, 05:19 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
both
Old 09-04-2005, 07:12 PM
IRACE87's Avatar
Car: 1987 IROC-Z
both
Now I wonder how long Viton seals would last on the exhaust.
Maybe I should stick with teflon seals on the exhaust but I never had a great success with them in the past.
PAT
Old 09-05-2005, 07:03 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Here are some Viton Positive Seals from Comp Cam, Edelbrock, and Trick Flow for both intake and exhaust.
http://store.summitracing.com/defaul....asp&x=22&y=11
Old 09-05-2005, 09:20 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
That is about the most resourceful valve seal link that I have seen so far!
Old 09-05-2005, 09:39 AM
IRACE87's Avatar
Car: 1987 IROC-Z
PAT
Old 09-05-2005, 11:06 AM
The worst part is that.. we all knew jegs.com existed but only one recently had the motivation to pull the link lol. I'm currently replacing my valve seals, the intake and exhaust valve seals that were on my car look like this.
The new ones have been a pain to slide on. I'm tapping them on with a small deep socket as light as I can but I already cracked one trying this method, fun.
Old 09-05-2005, 11:23 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Most of the seals listed there would require machining of the valve guide boss. You can't force a seal designed for .530" over a boss that is closer to .562"
Old 09-06-2005, 07:14 AM
yea, the ones that I got from the parts store must be to small. This pic shows where they get stuck. I need to just get a precision measuring tool rather then wasting money the wrong parts...
Old 09-07-2005, 07:03 AM
Ok I think I just found the answer to my problem. Near the botton of this article it explains how its safe to use the viton seals in place of factory nylon seals. They say that the vitons can hold up to heats of 450 degrees as the cylinder head often raises about 300 degrees. My valve stems must be oversized by a small bit because the fel-pro SS 72526 seals do not fit.
Here is a helpful link on valve seals.
http://www.federal-mogul.com/cda/con...6_7501,00.html
Old 09-07-2005, 07:48 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
What engine do you have?
According to PartAmerica.com 72526 and 72527 should fit. I used 72527 on both intake and exhaust.
Old 09-07-2005, 04:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Make sure you apply some oil to the insides of the valve seals and the valve stems themselves. That will help them slide down.
Old 09-12-2005, 06:27 PM
yea, your right, they "should" have fit. Its a stock 305 that came from an 89 RS Camaro, same L03 that was originally in the 89 bird. The engine was said to of been rebuilt by the dude who sold it to me. The intake/viton fit prefectly but the exhaust valve seals cracked no matter how lightly I put them on or with oil on the valve stem. I said screw it and put the 400 degree viton seals on intake and exhaust. On fel-pro's website they did have a car as an example of where they had to use viton on both intake and exhaust, it posed no problem since they can withstand high temps. If they give me anymore problems I'm going with my next upcoming solution that will fix many problems, the 350 swap.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Best positive valve stem seals ???
