How Does a Block Heater Work?
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
I've been told that all they do is circulate coolant, then why does is my car half way warm after I let it sit all night with it on? It's a dealer installed option, by the way.
Ludicrous Speed GO!!!
Speed Trap Exchange
[This message has been edited by MartyMcFly (edited October 06, 2001).]
Speed Trap Exchange
Car: 2002 SOM z28
I think my car had one of those too... I was like WTF is this extension cord that leads to the fire wall for I was going to dare to plug it in either... but when we pulled the engine, I saw that it lead to the oil pan or so... like a heating pad for that I guess.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Car: No more birdy
Theres one on my bird that was on it when I bought it, I never used it. The heater doesent circulate coolant it heats it. It works like a toaster. There is a little coil inside that warms up and heats the water. A nice thing to have if you live where it gets cold.
SSC
85 Camaro, 355/400 "drag car" in moth ***** 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firebird, 305/350 currently moth balled.
Current plans: Rebuild 305 with flat tops instead of the dished "cups" for pistons or slightly built 327 with the 58cc heads from the LG4, Upgrade the 2:73 to 3:73 or 3:42 and replace the turbo 350 with 700r4.
"It's Ripping time!"
"Web site under construction"
G0D Bless.
[This message has been edited by SSC (edited October 06, 2001).]
SSC
G0D Bless.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A traditional block heater is the heating coil that fits in one of the freeze plug holes. You plug it in and it keeps the coolent in the block at or near operating temperature.
I think the one you're thinking of is the recirculating heater. It's spliced into one of the heater hoses. These usually include a small pump in them to heat up the coolent and recurculate it through the entire cooling system.
The heating pad on the oil pan is just an oil heater. Using a good low grade or synthetic oil in the winter won't need the oil heater.
Old air cooled VW's had an oil heater. It was simply a dipstick with a heating coil on the end.
As long as you're antifreeze is at a low temp (usually -45) you're block won't crank. Trying to start a car with a cold engine and cold coolent is hard on the starter as well as the engine. Using a block heater just reduces the strain on the rest of the components when you're trying to start the engine that's well below freezing.
I usually don't plug my truck in until it gets below -20c.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
