what if you dont put the pushrods back in the same place?
Old 07-24-2005, 10:45 PM
Scheister's Avatar
Car: 85 IROC
i searched for 11 pages and didnt find an answer. so what happens if the dont go in the same place with new lifters?
Old 07-24-2005, 10:47 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
pushrods are cheap, why not just replace them?
in regard to the question, i doubt it will hurt anything
Old 07-25-2005, 12:38 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I never do. SBC pushrods are all the same length and you re-adjust them anyway. If they're worn enough to cause a problem in the lifters then you should have changed them. My BBC pushrods are 2 different lengths. Intake and exhaust length are different because of the way the valves are arranged. I pull all the pushrods and put them in a pile. Only the lifters if they're flat tappet need to be kept in order. Roller lifters don't wear in like a flat tappet so they can be mixed around.
All my spark plugs are indexed so they go back in the same holes also.
Old 07-25-2005, 04:58 AM
ede
ede's Avatar
i never do and have worked on a couple of SBCs now with no problems.
Old 07-25-2005, 10:05 AM
Scheister's Avatar
Car: 85 IROC
ok thanks. i was reading through some old posts that said you have to put them in the same places and i think i saw it in one of the 3 manuals i have. also when my cousin was helping me remove my heads ofcourse he pulled one off and they went everywhere...
Old 07-25-2005, 10:36 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
you have to readjust valve lash anyway and please get new lifters if your flat tappet, hydraulic or solid. It not worth the risk
Old 07-25-2005, 01:44 PM
Scheister's Avatar
Car: 85 IROC
yeah i know about gitting new lifters. the cam and lifters are already in.
camaro11j
09-19-2018 08:49 AM
bbsr72
Brakes
08-12-2015 10:44 AM
92projectcamaro
08-06-2015 01:20 PM
Quick Reply: what if you dont put the pushrods back in the same place?
