Can you use a 2 pc crank in a 1 pc block??
Old 09-28-2001, 01:59 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
I found a scat 9000 3.8 stroke crank (388) but it's for a 2 piece rear main. Can I use it in my 1 piece block?
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
Old 09-28-2001, 04:40 PM
wataru's Avatar
i dont think so. I am building a 355 right now on an 87 block which is a 1 pc and the speed shop ordered a 2 pc by mistake and i had to return it so they could get me the right one. Their might be a way to do but not that i know of.
'89 firebird formula tpi
custom cold air,gutted maf(just screens),52mm tb,ported plenum,edelbrock runners and base,headers with 3" catback,tb coolant bypass,afpr@44 psi,msd 6a w\blasterII coil,3.73 posi,sf connectors and corvette servo
Old 09-28-2001, 05:39 PM
johnsjj2's Avatar
Car: 1991 Z-28
Yeah you can use a 2pc. crank in a 1pc. block, but you have to get an adapter. I know Chevrolet makes them, I think Moroso does also. Summit or Jegs should have them. They are not very cheap either.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
Old 09-28-2001, 05:43 PM
ede
ede's Avatar
you need moroso pn 710-38415 from jegs for around 140 dollars. 1-800-345-4545
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
gta892000
08-11-2019 11:16 AM
MM2Robinson
10-01-2017 09:16 AM
customblackbird
10-01-2015 04:30 PM
camarohelp
09-22-2015 03:19 PM
Quick Reply: Can you use a 2 pc crank in a 1 pc block??
