visual diagram for rear end,,,ANY CLUE??
Old 06-16-2005, 11:52 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
is there any one on this forum , who could post up a diagram, showing detail of all the rear end parts for my 91 R/S camaro..
i have just gottin this ride, and when i got it up on the jack I saw someone had replaced something in the rear. only on drivers side in the rear its like a lil bar going latteral with red poly urathane bushings on itright next to the wheele,, im not talkin bout the traction bar...i just dont know the name of what im talklin a bout
the other side looks good prob why they did not replace it .. but i sure would like to know what it is
Old 06-16-2005, 03:02 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
if it goes diagonal from one end to the other, it's the panhard bar.
Old 06-16-2005, 06:40 PM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
If it's only a little bar then it might be the rear sway bar (or the link from the sway bar to the body, but that's vertial not lateral).
Mark.
Old 06-16-2005, 07:05 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Here's a link to Deadbird's site that shows the Camaro's rear end suspension, http://www.deadbird.org/pnc/c46.asp.
HTH
Old 06-18-2005, 06:30 PM
gottfuel's Avatar
dint help
yea that link did not help me,, im looking for a specific name for the piece im taliknin about ,, can any shoot me a link that shows the names of all componets in the rear, like a visual diagram?,'
the link was almost what i was lookin for but id did not lable the part im talkin about
Old 06-18-2005, 07:45 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Fig. 1: Rear suspension (exploded view)
http://www.autozone.com/servlet/UiBr...3d801643b0.jsp
try this double click once the web page comes up it will them be readable
If the parts not listed try to explain what your looking for so we could better help you
Old 06-18-2005, 09:51 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Wow! i have a feeling that page will be very helpful.
Old 06-18-2005, 10:34 PM
91blkta's Avatar
Great stuff found it one day by accident. Great diagrams even though there replacement parts are crap. They have all kinds of step by step instructions too. Not very detailed kinda like a haynes manual, but for a quick ref it helps.
Old 06-19-2005, 01:46 AM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
He's talking about the sway bar end links.
Old 06-19-2005, 03:13 AM
gottfuel's Avatar
yes yes!!
that is what i am talking about thank you for the diagram that helped a lot , now my original question was ,,,,,,,,,,, when i bought the car and looked it over i noticed that in the rear on the left side some one had replaced the sway bar end link... now i am noticing that i have to correct the stearing a lot at speeds over 40mph,,,,,,,,, is this the cause of some one replacing the end link and not alining the rear ??????????????
Old 06-19-2005, 08:31 AM
Jade Grey's Avatar
Engine: 305TPI
No, one swaybar endlink should not affect your steering at speed. Also you can not align the rear end on a stock F-body.
I would look for worn front-suspension pieces and have you car's alignment checked at a shop.
Old 07-15-2012, 10:35 PM
Chris142976's Avatar
Car: 1991 trans am firebird
Transmission: turbo 350
Axle/Gears: 5.13
Re: visual diagram for rear end,,,ANY CLUE??
hey guys i have a 91 trans am i am building into a drag car its a t top but i look under the rearend and i see things missiong all i have holding my axel on is the shocks and springs....please someone post a diagram or something to show me what i need to get it back the way it needs to be
Old 07-15-2012, 11:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Post pictures of the front and back of the diff and we'll tell you what's missing.
Old 07-16-2012, 09:23 PM
Axle/Gears: 5.13
http://www.facebook.com/media/set/?s...6433062&type=1
this is the link to my pictures the last ones will probably help you more but i wanted to make sure you seen it all.....whats mising the sway bar etc......this is the only thing holding me up..thanks..idk how to post pics here
Old 07-21-2012, 09:42 PM
Axle/Gears: 5.13
hey any ideas on that rearend?
Old 07-21-2012, 10:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Can't see anything. Either facebook is screwed up or won't display to non members.
Old 07-22-2012, 01:52 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Panhard bar and the traction bar(s) are missing. I think I saw a few missing brake lines too, but couldn't really tell. Oh and your gas tank.
Old 07-22-2012, 03:02 AM
Axle/Gears: 5.13
lol i dont need a gas tank its goin to be a drag car i have a fuel cell inside the car...thanks again and if you notice anything else please let me know
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
Jlanz55
08-17-2015 07:15 AM
BlackBoulder
08-11-2015 11:15 PM
Quick Reply: visual diagram for rear end,,,ANY CLUE??
