Clear, see-through valve covers?
Old 05-03-2005, 09:32 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Does anybody make clear, see-through valve covers?
I saw some on a show car years ago, and they looked pretty cool, but I've never been able to find any!
Thanks.
Craig
Old 05-03-2005, 10:16 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
As soon as you started the engine up you'd want your money back, as the oil splashed on them would obscure any view of the valvetrain.
In addition unless your rockes say Jesel or T&D on them they ain't worth seein anyway...
Old 05-03-2005, 10:22 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Maybe not! I still think they would be cool--at least I'd know they were oiling! They would definaely be a topic of discussion at the Sat night car shows/meets!!!
Old 05-03-2005, 06:11 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Not true. I start up engines all the time with the valve covers off. As logn as its JUST idling it wont be shooting all over gods green earth.
Old 05-04-2005, 01:40 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Forgive me, but function should always be preferenced before form.
Old 05-04-2005, 01:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Yes, and the function of the rocker covers is to keep the oil in. I wouldn't want them, personally, but it doesn't seem like they would fail to meet that objective just because they were clear.
Old 05-04-2005, 01:52 PM
SSC
SSC's Avatar
Car: No more birdy
It's a show car item, you know those engines that have 6K+ in them and will never see oil. A few heat cycles with splashing oil will make them turn completly white. Yea they would look
Zap Racing's Avatar
Car: 1989 IROC Z-28
I agree!!
Old 05-04-2005, 02:00 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I disagree--if the correct type of plastic is used the temps that oil get to (even if your car overheated) will not cloud them. That I know for a fact! Which type of plastic--I do not know--I'm not a metalurgist, or in this case I guess that would be plasticurgist!
Old 05-04-2005, 02:13 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
They would also have to be extremely good at shedding oil.
Heat resistance, oil shedding, and transparency all in one plastic?
I'm from Missouri...
Old 05-04-2005, 02:16 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I'm from Texas.....it's already been proven! Probably somebody from Texas did it!
Old 05-04-2005, 03:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
I've seen them for sale before. I can't remember where but i saw them a couple of time. Look in race car catologs and search the web, or ebay. Nothings to hard to find these days !
But they are pretty expensive $100+
Old 05-04-2005, 04:38 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
100.00 is not all that expensive, considering the price of some of the hand formed alum. are in the 300.00 range.
Old 05-04-2005, 08:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You would like to see what's under my valve covers but I wouldn't spend the money on clear covers. The plastic will turn white after it's been cooked by the oil and you'll never see what's under the covers while the engine has been running for a while. For the inside of the covers to be perfectly clean for display, you're still going to have to remove them to clean them right up. Oil residue will always be stuck on the inside.
There's always the chance of the plastic cracking and causing a leak.
I suppose you'd want some neon lights on the inside also?
Old 05-04-2005, 08:45 PM
Apeiron's Avatar
Engine: 383 Carb
Let's not get carried away. LEDs would be perfectly adequate.
Old 05-05-2005, 09:34 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
BITE ME!!!!!!!
Apparently I'm not the only one who has thought about this. Below is a link for this co. that is coming out with them!!!!!!!!!!!!!
http://www.cleargearz.com/
Look on the new products area!
Regardless of what others think, I WILL have some as soon as they are available.
Old 05-05-2005, 09:53 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Probably not the best way to handle your comeback "Bite me" , but I agree that this item would work. I have used many composite covers, noteably the ones from comp cams, and many OEMs use alot of plastic in the newer engines. As far as the oil depositing onto the covers, I have no idea what you guys are using for oil or how long you are waiting to change your oil, but when I remove my valve covers they do not have oil or deposits on the inside of them. I have seen the clear plastic valve covers and differential covers, I personally think they are pretty neat, and a good idea. I wouldn't mind being able to inspect my valvetrain after a high RPM blast down the strip, without having to touch one bolt.
Old 05-05-2005, 10:09 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Yes, I agree, but it seemed appropiate and on the same level of intelligance!
Old 05-05-2005, 10:15 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Personally, I change the oil when it starts getting darker regardless of how many miles it has been. I don't know what some "other" people do, but having raced drag cars as well as several sucessful years racing circle track car ( including one year as crew chief on a local season points winning sprint car) changing oil at a time or mileage interval is about the stupidest concept I have ever heard. When it gets dirty--IT'S TIME TO CHANGE IT! I don't have all the time and money in my IROC so I can abuse it.
Old 05-05-2005, 11:58 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Someone must not understand the purpose of valve covers. They're just going to get really really dirty, really fast. It's honestly the dumbest idea you can waste money on. If you're going to use it to see what color your oil is, wow just use the dipstick.
Old 05-05-2005, 12:30 PM
SSC
SSC's Avatar
Car: No more birdy
Well for a fact the one on the market do turn white if used on a engine that runs same as the clear distributor cap which doesent see oil at all. There a hose place across from our shop, the guy does hyd crap for low riders thats where Ive seen the clear VC and what happens to them. I dont think there is a material out there that would hold up in this situation. Of course we could hold out for transparent aluminum.
Old 05-05-2005, 12:49 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
ONLY if Scotty will give the formula!
Old 05-05-2005, 12:57 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Well, everybody IS entitled to their own personal opinion!
Old 05-05-2005, 01:43 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Yea I guess checking all the retainers and lockdowns on your roller rockers after turning 6000-6500 rpm for an extended amount of time, would be useless. The term "Plastic" I think may be confusing people. What could be used is a poly class filled resin impregnated with silicon (the same stuff that is on your spark plug wires and seals). No it is not transparent aluminum, but it is very strong and heat resistant, and if you look at some of your sensors, you can touch it first hand. We actually use a clear resin when we are testing sensors on prove design machines and such, so we can check for moisture entry problems and what not.
Old 05-05-2005, 01:46 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
I guess to throw some fuel on the fire, honestly the dumbest thing you can waste money on is the TORNADO or Leaf blower supercharger. It is my opinion clear valve covers have much more merit than those things. As far as the valve covers getting dirty, that is a personal hygiene thing. My valve covers stay VERY VERY VERY clean!
Old 05-05-2005, 02:27 PM
ME Leigh's Avatar
Car: 82 Z28
Its not the dirt in the oil that the problem. Its the acid buildup, which is a product of the combustion process that is. This is why synthetic oils are better, they tend not to get ruined by the combustion process as fast.
Its a good idea to change your oil every 3 months anyway regardless of mileage to get rid of the destructive chemicals and acids now in the oil.
Old 04-30-2011, 02:41 AM
JAVY56's Avatar
Re: Clear, see-through valve covers?
Hello,
I've had these valve covers on my 56 Chevy since 1996 which I made.
Not sure if pictures showed. New to posting pictures.
www.jandjengineeringinc.com
thanks
Attached Thumbnails Clear, see-through valve covers?-56.jpg   Clear, see-through valve covers?-56valvecover.jpg
Old 04-30-2011, 02:56 AM
JAVY56's Avatar
TOKEN,
Not sure how to highlight your post ???
"Someone must not understand the purpose of valve covers. They're just going to get really really dirty, really fast. It's honestly the dumbest idea you can waste money on. If you're going to use it to see what color your oil is, wow just use the dipstick."
I can always be sure oil is trickling out of push rods for comfort.
Couple of years ago , covers became cloudy even though dipstick was clean.
Turned out my intake manifold was loose from rear bolts and coolant was seeping through. Tightened them up , changed oil and all is good. I made them for cosmetic reasons but there have been advantages.
thanks
Javy56
Old 04-30-2011, 08:16 AM
jt1562000's Avatar
Car: '88 IROC-Z
Engine: 383 Stroker
Javy...I really like those! I can see many advantages to being able to see the valve train without having to pull the covers. I think completely clear valve covers would be a little too much, but that window is a great idea.
I have a set of valve covers that I ran on my dirt track car that has a removable panel right where your clear window is. It makes valve lash adjustment and valve checks really easy between races. I may look into changing the panel out for a removable window.
Old 08-13-2011, 06:07 PM
Couperdecar's Avatar
Theres a set now on flea-bay. $175
http://api.viglink.com/api/click?for...13132768302503
Old 08-13-2011, 08:11 PM
DENN_SHAH's Avatar
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
sadly Craig, or Zap Racing as he was know here is no longer with us.
if you had only came here a few years sooner JAVY, im sure Craig would have loved to see your motor with those valve covers on it.
Old 08-14-2011, 08:11 PM
My condolences
Old 08-14-2011, 09:04 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
When I saw the thread title, I expected to see 100% acrylic/lexan valve covers, not just clear insert tops.
Anybody ever seen 100% clear ones?
Old 08-17-2011, 03:32 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
if u really want them heres a link for a pair
http://cgi.ebay.com/ebaymotors/clear...mZ230246522516
Old 02-01-2012, 03:23 AM
Twin_Turbo's Avatar
Here is a listing for the original ones, be aware the seller is likely a crack addict seeing what his asking price is
http://www.ebay.com/itm/NOS-VINTAGE-...#ht_500wt_1180
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
Nick McCardle
09-10-2015 08:36 PM
tgp1990
09-04-2015 06:24 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Clear, see-through valve covers?
