What are the symptoms of loose/tight valve lash?
Old 08-10-2001, 10:00 PM
Xenodrgn's Avatar
ok, it just occured to me....
I thought I had an ignition problem, but I'm not so sure... my plugs are fouled, and the car is very weak (at least seems like it).
In the engine bay I can hear a ticking, it's noticeable, and has gotten more noticeable since I got it 4 months ago. i -thought- it was the injectors ticking, but now I'm not sure... can maladjusted valve lash cause these problems? How much of a job is it to adjust them? So get my covers off I think I would have to remove my intake, but from what I hear the car has to be running, any thought?
Am I on the right track, or should I go back to my orignial idea (the bad ignition).
any thoughts?
PS, I don't -believe- the engine has ever been opened up, although I don't know... can they loosen over time?
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old 08-10-2001, 10:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They often do loosen over time, as parts wear and all that. They rarely tighten themselves except when a valve seat wears through and the valve rests against soft metal; then that erodes real fast, and the valve moves upward in the head, and it can get to the point where the valve train holds it open.
I don't even know if a 2.8 has adjustable rockers. If it does, you could try adjusting them. A rolled cam lobe also makes what sounds like a tick, although if you could slow it down, it would probably be a squeak.
I don't think you have to pull the intake to get the valve covers off but i could be wrong. I don't know anything at all about the details of the 6-cylinder motors.
ICON Motorsports
Old 08-10-2001, 10:19 PM
Xenodrgn's Avatar
Thanks, I'll try posting this over in the V6 forum.
BumpaD82
02-26-2016 02:57 PM
355tpipickup
09-13-2015 11:35 PM
sandman92084
09-12-2015 10:27 PM
dimented24x7
09-06-2015 03:51 PM
Quick Reply: What are the symptoms of loose/tight valve lash?
