How can you tell if a knock sensor is bad?
Old 04-14-2005, 11:31 AM
white80zred89rs's Avatar
Car: 89 camaro rs
I would just like to know some of the symptoms of a bad knock sensor. My 89 305 TBI is pinging when it's warm, and it doesn't seem to change when I put different fuel in. It idles strange too; when it's warm and you've been romping on it, it can't keep a steady idle speed. This changes though a little depending on the gas you put in. It has even died on me a couple of times at a stop light, but always starts back up again. Performance hasn't changed noticeably, and I'm still getting around 20 mpg average. No trouble codes either. It's not the EGR valve or anything that has to do with the TB.
Any ideas?
Old 04-14-2005, 03:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
There was a time where you could watch the timing marks with a timing light, lightly rap on the exhaust manifold with a hammer and if the knock sensor was working, you can watch the timing marks retard.
Old 04-14-2005, 10:34 PM
Car: 89 camaro rs
Where is the knock sensor located anyway? I heard that there may be more than one also; is that the case on an 89 305 TBI?
Old 04-15-2005, 11:07 PM
trans_am_ta_84's Avatar
Car: 89 trans am
it's on the passenger side of the block and i beleive it's under the manifold.
Old 04-16-2005, 02:30 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Passenger side coolant drain hole... its right near the starter.
Old 04-16-2005, 10:38 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
what happens if your knocksenser is not hooked up? becuase my car runs fine but i think it's a little weak than it should be.
and oh it might be the 170000 miles on the car lol
Old 04-17-2005, 01:07 AM
Air_Adam's Avatar
If its not hooked up, IIRC, it will go into a preset "limp home" mode, which seriously kills everything... no power, poor running, and bad mileage.
Old 04-17-2005, 09:55 AM
Car: 89 trans am
well like air adam said it won't be alittle weak it will be like running on 5 cylinders. it retards the timing and then the car won't even want to move.
Old 04-17-2005, 11:01 AM
3rd gen V8's Avatar
well my car drives just fine thoe but the sensor is unpluged and i cant find the wire that went to it either.
Old 04-17-2005, 12:04 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
pull it out put a volt meter on it and tap it with a piece of metal and see if the reading jump between .5-1.5 volt or somere around that. put the black volt meter prong on the threads and the red on the connector.
Chuck84TA
07-15-2016 09:05 PM
db057
09-04-2015 07:57 AM
bamaboy0323
09-03-2015 06:07 AM
db057
08-22-2015 08:17 PM
Quick Reply: How can you tell if a knock sensor is bad?
