Head casting number 14102193?
Old 04-06-2005, 03:20 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I ordered a set of 2.02/1.60 heads for my L98 project motor and specified 14101083 heads.
They sent me 14102193's? Are these an equivalent or did they screw up? I checked the casting number and it says they are 87 - 92 or so 350 head and they do have the correct bolts for my TPI. I am afraid they may be those junk swirl port heads used on the truck motors.
Any ideas?
Old 04-06-2005, 03:38 PM
11 Flat's Avatar
Send them back!!! Those are Swirl Port Heads.
Old 04-06-2005, 03:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are NOT equivalent. They are in fact truck TBI swirl-port heads.
Send them back, and make them supply what you ordered.
Old 04-06-2005, 05:28 PM
Supporter/Moderator
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Since they sent you the wrong head I would demand that they give you what you ordered. The is no way you should settle for those heads when you asked for L98's.
For what it worth to those that have a set of these heads collecting dust in their garage.
In "zero money" situations these heads can be used. They should never be used without port work though. New light is being shed on this head for low RPM TBI applications. These heads can make decent power and flow decently under 4500 rpm. With the right cam you can maximise what little performance you can muster out of them. This does not mean that they can be used in any serious performance engine, but merely as an semi-performing substitute. Read this thread to see for yourself and the results that one member had not giving up on these heads. Vortecs and TPI heads would be much better choices but if you have a low RPM torque motor, that behaves much like TPI and TBI, you have a chance to get at least something out of them.
https://www.thirdgen.org/techbb2/sho...hreadid=283217
Old 04-06-2005, 09:29 PM
TKO500's Avatar
Thanks for the info and that thread. I just emailed them to see the response I get. If they dont have a set of 083's I am sending them back on their dime since I found the email that stated they had 083's ready to go.
Old 04-24-2005, 01:12 PM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
Well!!!!!
What was the outcome?
Old 04-24-2005, 01:20 PM
TKO500's Avatar
The 083's came in last Thursday and the others are going back! They were real cool about it. Now it's time to assemble the motor!
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
02-28-2016 03:33 PM
camaro71633
09-01-2015 10:24 AM
BlackphantomZ28
08-22-2015 01:00 PM
dcbsracing007
08-18-2015 07:24 AM
Quick Reply: Head casting number 14102193?
