Streetmaster Rochester Quadrajet
Old 04-02-2005, 11:16 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
What do you guys think about the Streetmaster Rochester Quadrajet from Jet Perfomance Products (The Stage 2 Version)?
Does it go right in the place of the old quadrajet, and hook up to all the computer controls? Is this just a rebuilt quadrajet?
Most of all, what performance gains do you think I will see over the stock quadrajet?
http://www.jetchip.com/
Old 04-02-2005, 11:38 AM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, if you look at the pic this is an emission carb but not for the CCC system. I don't see a M/C solanoid.
Auggie
Old 04-02-2005, 11:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Jet will modify your CCC carb though, you can contact them for details. Some people say that Jet's work isn't as good after Sean Murphy left to start his own business.
Old 04-02-2005, 11:59 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
well im not buying one direct from jet, im buying it off a friend that says it will work completly with the computer
Old 04-02-2005, 12:05 PM
Auggie's Avatar
I don't think so. Like I said the pic does not show any M/C solanoid. Call Jet.
Auggie
Old 04-02-2005, 12:12 PM
Apeiron's Avatar
Engine: 383 Carb
The picture doesn't tell the whole story. CCC carbs are available from Jet.
Old 04-02-2005, 12:23 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
what exactly is a CCC carb and an M/C solonoid, ill ask to see the carb he is selling and I will see if it has it
Old 04-02-2005, 12:27 PM
Apeiron's Avatar
Engine: 383 Carb
CCC stands for Computer Command Control. It was GM's name for their feedback carb setup. the MCS is the mixture control solenoid, the computer tells it to move the primary metering rods up and down to control the mixture.
Old 04-02-2005, 12:29 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
does anyone have a picture of what the M/c solonid is, also how much does one of these carbs cost new?
Old 04-02-2005, 02:49 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
if this carb was on an LG4 engine, and it worked fine with the computer, would it work fine with my L69? and if it dosent have a Mixture control solenoid, would i get a check engine light?
If anyone has a pic of the MCS that would be great, thanks.
Old 04-02-2005, 03:01 PM
Apeiron's Avatar
Engine: 383 Carb
If it was on a computerized LG4, then it has an MCS and it should work fine on an L69.
Old 04-02-2005, 03:02 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
did any other GM companys use the LG4, like buic, pontiac etc?
Old 04-02-2005, 03:10 PM
Apeiron's Avatar
Engine: 383 Carb
Yes, they pretty much all had at least one LG4-equipped model.
Old 04-02-2005, 03:16 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
and if it worked on a buic LG4 it would work on a Chevy LG4 which would work on a L69 right?
Old 04-04-2005, 11:11 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Probably. The L69 was tuned a little differently, and some LG4 carbs had restricted AV opening, and L69's didn't.
Old 04-06-2005, 05:38 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
i would get the proper cfm carb and then tune it to your fuel needs--all engines will not be the same--food for thought
later and gb
rk
Old 04-06-2005, 06:01 PM
five7kid's Avatar
Engine: LS1/LQ4
That's the beauty of the q-jet carb. It's the proper size on so many different engines, up to the point you "need" more than 750-800 CFM.
Old 04-06-2005, 07:10 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
so will i notice a difference over a stock q-jet?
and are these new or just rebuilt to higher specifications?
Old 04-06-2005, 07:21 PM
five7kid's Avatar
Engine: LS1/LQ4
Depends upon the condition and tune of the stock q-jet.
The latter.
Old 04-06-2005, 08:34 PM
Apeiron's Avatar
Engine: 383 Carb
It should be noted though that "parts-store" rebuilt Q-jets are not necessarily (or even normally) rebuilt to the same or higher specifications than stock.
PurelyPMD
05-05-2016 04:57 PM
sreZ28
Carburetors
24
09-21-2015 04:54 PM
Scorched1984
09-15-2015 03:42 PM
armybyrd
Carburetors
25
09-13-2015 01:49 PM
Quick Reply: Streetmaster Rochester Quadrajet
