Cam lube?? On a roller cam???
Old 07-11-2001, 09:49 AM
Kat
Kat's Avatar
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Well the manufacture says to not to use anything on the roller cam since it s a roller cam... I've heard different over the years .. From what I am led to beleive you need some sort of lube on the bearing section of the cam..
So what should I use. Assembly lube or will some 10W30 work?
Kat
Old 07-11-2001, 10:02 AM
sleeper's Avatar
Might as well put some on anyway. Not like it's going to hurt anything.
Old 07-11-2001, 10:17 AM
greearhr's Avatar
The rollers/lifters should be soaked in oil. That's all they need. The cam journals still need some lube. Use the same breakin lube as the crank mains/rods.
Beartracks
Old 07-11-2001, 10:38 AM
ATOMonkey's Avatar
I've always built engines with plenty of 10W30 Engine oil. Never had one fail.
'87 Bird 350 .060 over 700R4 + Lots more
Old 07-11-2001, 04:32 PM
kevinc's Avatar
Car: 1982 Z28
Thin coat of assembly lube on the walls of the lifter bore, soak the lifter in oil as mentioned above, and pop it in. You don't want the assy lube on the roller or cam, you do want it between the lifter body and bore.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old 07-11-2001, 07:03 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
when i assembled my engine I used lube both on the camshaft AND on the body of the lifter..
i also used lube on the pushrods and anywhere the rocker arm had friction..
i pre-soaked my lifters in oil, and use an old pushrod to 'prime' them..
my car had no problems firing up and runs fine still
Webmaster: www.IROC-Z.org
Old 07-12-2001, 07:08 PM
ede
ede's Avatar
i use lubiplate 105 on the bearings and lifter bores, oil on the lifters and moly lube on the cam lobes.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
TX-SleeperC5
02-24-2016 01:34 PM
Jorlain
10-08-2015 01:57 AM
Nick McCardle
09-10-2015 08:36 PM
Strick1
09-04-2015 07:11 AM
Quick Reply: Cam lube?? On a roller cam???
