TPI Intake Manifold Torque specs
Old 06-18-2001, 02:52 PM
Ben87GTA's Avatar
What is the correct torque for the intake manifold? Also, what should I set the timing at when I redo it? (stock..)
Old 06-18-2001, 03:29 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
25-45ftlbs according to my GM manual. Since it was such a wide range, I just use the old SOTP torque wrench.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old 06-18-2001, 03:33 PM
Ben87GTA's Avatar
SOTP?
Old 06-18-2001, 04:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Seat Of The Pants. Although, I personally don't prefer torque my intakes that way.
Torque always goes with hardware size. Look at the bolt, it carries its torque spec with it. 3/8" std thread should get about 30-35 ft-lbs. no matter whether it's an intake bolt, a bell housing bolt, water pump, exhaust manifold, etc.
ICON Motorsports
Old 06-18-2001, 07:08 PM
rondubbs's Avatar
http://www.racer-x.f2s.com/proc/torkseq.htm#tpiseq
do it in this sequence and here are the torque specs...
stock timing is 6*, you may want to advance it to 8*, see if it gives you more power. if you have a scanner advance it as high as possible without any knock detection..
good luck
Old 06-19-2001, 08:23 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Here are some other specs you might find useful.
http://www.gmtips.com/3rd-degree/dox...ecs/torque.htm
Old 06-19-2001, 08:51 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Use a stubby 9/16 wrench and tighten them as tight as you can with one hand from the center out to the ends. Ditch those T-40 head intake bolts because you can't get at them with the runners on and go with the hex 3/8-16 bolts.
You must go back after a couple heat/cool cycles because they loosen up to the point of being finger tight after a week or so.
Jake_92RS
01-28-2020 10:37 PM
Zeek1041
Theoretical and Street Racing
08-21-2015 08:45 PM
86IROC112
08-17-2015 02:00 PM
st.evel07
08-13-2015 06:15 PM
Jake_92RS
08-11-2015 10:39 AM
Quick Reply: TPI Intake Manifold Torque specs
