Oil Leak, is it my front seal?? Help!
Old 12-31-2004, 10:48 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Hey guys, I have not been driving my RS much lately but last week it was warm and I took her out to keep things lubed up. No sign of oil drips anywhere, and oil level was still totally full. Well today I was looking under the car and saw a small oil drip about the size of a quarter. I looked up and I can see oil under the crank pulley and on the front of the oil pan just underneath the crank pulley. What type of leak is this??? Is this my front seal??? IF so, how much do these things cost to fix at a shop???
Old 12-31-2004, 10:53 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
It could be the front seal or anything above it leaking and dripping down. If it is the seal the good news is the seal and gaskets run about $10. "I "can change the front seal in about 2.5 hrs. A mechanic can check the book time and give a firm quote. Sometimes a groove is worn in the balance shaft from the seal. A repair sleeve can be used for a fix. These run about $10 also. If it is worn too deeply a new balancer is in order. You will not know until it comes apart.
Old 12-31-2004, 11:47 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
The front seal is an easy fix, remove belt, pulley then damper. (removal/re-installing the damper requires a special tool) While you are at it, examine the damper closely to make sure it the rubber inbetween the damper is still good.
Old 12-31-2004, 05:13 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
PIC!
Here is a pic of the leak I was trying to describe. Hopefully some more people can chime in on this thread and give me their opinion.
Old 01-01-2005, 11:09 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
i have the same thing and my car has been siting for only 3 months help this guy and help me
Old 01-01-2005, 11:31 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
No discernable oil missing? So it's just weeping. Happens a lot, don't worry about it unless it is going to ruin your driveway or are **** (some of us have been rumored to be). If so then try and fix it. Typically, I'd do the timing cover and the oil pan gasket at the same time... but I allegedly fall into the previously referenced group.
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
Navy8125
08-21-2015 09:32 AM
86White_T/A305
08-17-2015 12:16 AM
Exxon Limited
08-09-2015 08:13 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Oil Leak, is it my front seal?? Help!
