broken case
Old 12-13-2004, 04:31 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
broken case
I pulled my t-5 yesterday to replace the TOB. when i slide the trans off the bellhousing i noiticed that one of the ears that hold the trans to the bell was broken. does anyone know what would cause this.
Old 12-15-2004, 10:27 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Using the trans bolts to draw the trans into the clutch/bellhousing without everything lined up first. The ear gets stress risers from the force being exerted on it, and then cracks later due to vibration. You can probably get it heli-arc welded back on for about $50 or so at a welding shop.
Old 12-15-2004, 01:57 PM
well every time i have had to pull the trans we have just lifted and pushed. so i know it is not from me doing it. but that doesn't mean that some one else didn't do it in the past. but there where no cracks or any thing the last time i pulled it. will this effect clutch disengament or anything else?
Old 12-15-2004, 02:10 PM
This is a bad situation. With a broken ear you are putting the force designed for 4 bolts on just 3, and only one bolt on one side means that it takes all of the force on that side. It won't affect clutch action, at least not until the other ear breaks and then maybe something really bad happens.
You should really just get the broken ear welded back onto the case. It's not a big deal as long as it's a clean break which it usually is. I've had several Muncies fixed this way over the years, and have seen a lot of transmissions fixed like this with both aluminum and cast iron cases.
Old 12-15-2004, 02:47 PM
well i will try to get it fixed as soon as i can. right now i am jobless so i will have to wait to get the income to get it fixed. thanks for the help.
Old 12-16-2004, 07:08 AM
I know what that's like.
Take it easy on it and it should be okay for at least the short term.
sheachopper
07-31-2019 11:27 AM
no green
01-09-2016 09:22 PM
Galaxie500XL
10-01-2015 01:05 PM
Badass355ciz28
09-28-2015 08:31 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: broken case
