how to adjust drum brakes??
Old 06-02-2001, 10:29 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I read the chiltons and it was not the most clear explination. aparently I adjust the spacer in between the shoes at the bottom of the drum until it lets the drum rotate with some resistance -- then back off 12 clicks??
anyone have a tried and tested method for getting the drums adjusted just right?>>?
James
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
http://www.geocities.com/transam617
Old 06-03-2001, 02:34 AM
coach's Avatar
I haven't tried what you said. When installing shoes I just turn the adjusting screw wheel to the point where the drums will fit over the shoes. With new shoes the adjusting screw wheel usually has to be at its starting position. Once everything is back together. I make several-short forward and reverse stops. I keep making short passes until the brakes feel firm. That's just the way I've always adjusted the drum brakes on my camaro.
Old 06-03-2001, 08:05 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
hmmm
well the chiltons seems to be a little more specific and I was thinking that somehow you have to set them to a certain tolerance and then they self adjust like you said during stops.
I just wish that a real mechanic could tell lowly me what the right way is to do this....
gmtech, im looking in your direction....
Old 06-03-2001, 11:37 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I'm not a GM Tech, but I took some auto repair classes at my local junior college. The shop teacher said in GM cars, that's all you gotta do on rear drums. I have a Haynes Repair Manual in front of me and it says, "Make a number of foward and reverse stops to adjust the brakes until a satisfactory pedal action is obtained." These Haynes books are made for shade tree mechanics like ourselves. It's all in simple terms and includes pretty pictures on how to do stuff. It's really cool actually.
Don't do like I do all the time and make something harder to do than it actually is. I do that all the time. Then I get ticked off due to my own ignorance.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old 06-03-2001, 12:52 PM
Guest
Guest
Posts: n/a
Like said above, they are self adjusting. I just do whats above, adjust the self-adjuster until the brakes are near the drum and then go make a bunch of short stops. If they are too far away, then the brakes just wont work real well until they adjust to the correct spot... just make sure you keep in mind it may not stop as well until they are adjusted right, so stay away from cars and walls and such
Old 06-03-2001, 02:22 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Is there a hole to get to the adjuster in the backing plates?? (some have this, some have a hole in the front of the drum)
If so, adjust the shoes so they are close to the drum and then install the drum and wheel.
With the car still on stands and in neutral, rotate the tires by hand and adjust the star wheel (through the hole) with a brake adjusting spoon or a screwdriver till there is a drag on the drums.
If the hole is in the front of the drum, just install the drum and a lug nut or 2 without the wheel. Adjust the same way as stated above.
If there is no hole anywhere, just adjust the shoes so the drum is tight going on, this will be perfect. Be sure to set the E brake a couple of times because the brakes will use the E brake arm to adjust properly.
Hope this helps you out.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old 06-03-2001, 04:24 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Ahha.
thanks for all the help guys I guess I am just making a mt out of a molehll.
but that does bring me to the other thing I cant understand completely in the chiltons which is the E-brake adjustment.
and you say that its adjustment effects the rest of the brake also???
please explain e brake tuneup for my un-educated a**.
Old 06-03-2001, 10:16 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
This is for drums only....
You should never need to adjust the e brake.
When you run out of ebrake adjustment it is usually a sign of worn out or out of adjusted rear brakes.
When the rear brakes are installed and adjusted correctly, the e brake will be perfect.
For anyone that has a stretched cable, you can adjust the e brake by turning the nut in line with the cable where the 2 rear cables meet and become one.
Some disc rears (newer f bodies and others)
use little shoes inside the rotors for the e brake....these need replacement from time to time.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited June 03, 2001).]
Linson
11-12-2015 08:09 PM
SpaniardV6
Brakes
19
09-07-2015 03:04 AM
Night rider327
09-02-2015 04:17 AM
masonta
09-01-2015 06:40 PM
Bstrang6
Brakes
08-24-2015 06:45 AM
Quick Reply: how to adjust drum brakes??
