DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
16197427 pinout
Old 11-20-2004, 04:03 PM
MrBill's Avatar
16197427 pinout
Anybody have a harness connector pinout diagram for a 16197427 PCM?
Bill
Old 11-21-2004, 09:59 AM
HaulnA$$'s Avatar
Re: 16197427 pinout
Bill
Here you go. ftp://ftp.diy-efi.org/pub/gmecm/manuals/16197427/ . HTH
Old 11-21-2004, 10:04 AM
MrBill's Avatar
Sweet. Thanks!
Old 11-21-2004, 11:17 AM
HaulnA$$'s Avatar
Are you cooking somethng up for this PCM? If so, count me in. I have a lot of info on this PCM and have been messing with it for a while.
Old 11-21-2004, 11:38 AM
MrBill's Avatar
No, not really. I'm building a Prominator for a 512K PCM and just need to set up this 7427 I have to test it with.
Sorry to disappoint. LOL
Old 11-22-2004, 10:27 PM
89350STRO's Avatar
Hey HaulinA$$,
I've been searching for a component/board level schematic like the ones on ludis' page for the 16197427. Any Ideas on where to find one??
Sorry, didn't mean to hijack the link but ...... the ? is semi-related.
89350STRO
Old 11-22-2004, 10:53 PM
HaulnA$$'s Avatar
Hey 89350STRO, I have not found any specific schematics for the '7427. It has some similarities to the 1227747 such as the injector driver circuits but that is as far as I got before giving up. From what I can tell, it is a hybrid of the P4 ECM (faster cpu and aldl, no onboard ROM, etc.) and the older C3 ECM (peak/hold injector drivers) with added transmission control. Sorry, that is the best I can do. If you ever come across schematics, let me know. HTH
Old 12-07-2004, 02:49 PM
MrBill's Avatar
What about pinouts for a 16196395? Same as the 6396?
Old 12-07-2004, 03:34 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
try this website, lots of interesting stuff. look under wiring, and there should be numerous late model ecm stuff for trucks.
http://www.megspace.com/cars/16147060/index_tk.html
good luck!
Old 12-07-2004, 05:10 PM
MrBill's Avatar
Need a pinout for a 16191947 now. Anybody?
Old 12-07-2004, 07:11 PM
HaulnA$$'s Avatar
They are the same as the 16197427. It is the same PCM. HTH
Old 06-12-2006, 03:45 AM
kyanox's Avatar
So i found this thread but im confused.
For the Jbody project i'm converting a ln2 pcm that runs in a s10 with the ln2 engine to run in a 95 cavalier with a manual trans and the ln2.
My question is, where can i find the pinout to the 16196285 and 16196395 pcms.
I have a sacrificial pcm to get female connectors and i have male connectors, and so what i need to know is where the pins plug. Im doing some google searching, so i will let you all know if i find what im looking for.
I still am benching the 16196285 pcm, but im finding the the 36 mask is uncommented and hard to figure out.
Old 01-04-2010, 05:20 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
Re: 16197427 pinout
3 years later, any luck with that 16196395 schematic? 1/04/2010
Old 01-11-2010, 05:10 AM
Glenno's Avatar
Car: 1990 Jeep YJ
Re: 16197427 pinout
bump
Old 06-07-2011, 10:11 PM
EagleMark's Avatar
Re: 16197427 pinout
bump
Same as the 16197427 is the 16197395. Wiring diagrams are here:
http://www.gearhead-efi.com/Fuel-Inj...CM-Information
InfernalVortex
04-20-2021 11:31 AM
ChristinaMarie
09-11-2015 06:28 PM
Jackrabbit501
09-02-2015 09:14 PM
BigJohnson
DIY PROM
07-26-2003 05:32 PM
Doward
DIY PROM
02-01-2003 06:59 PM
Quick Reply: 16197427 pinout
