How much rear wheel horsepower on a 87 350 TPI?
Old 11-19-2004, 12:34 AM
66impalaTPI's Avatar
Car: 96 impala
Transmission: 4L60e
I wanted to know how much rear wheel horsepower I can get out of this engine without changing anything internally. Does anyone have dyno numbers? Any numbers at all?
Old 11-19-2004, 12:47 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
if you're only doing external mods...I would guess anywhere between 220-240 and that's if you get the tuning dead on.
Old 11-19-2004, 01:02 AM
Car: 96 impala
Transmission: 4L60e
220-240 rear wheel horsepower, just external mods? That seems really low. Does this include headers with exhaust cut outs and a fully ported intake manifold, runners, and plenum? Does anyone have this setup without changing anything internally?
Old 11-19-2004, 01:18 AM
if you add all those you will get some more hp but remember the best year for the iroc was '89 when it made 240hp brand new and you said yours is '87 350 tpi which i think was rated lower than 240..thats 17years ago and the thousands of miles they racked up over the years induced a lot of wear and tear which always significantly reduce hp and torque numbers on these engines...my point is that worn out internals is gonna put a limit on how much power you can squeeze out of it and this is not only for tpi motors.
Old 11-19-2004, 01:30 AM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
91 GTA 50k miles
24# injectors and SLP catback are the only mechanical mods.
I do my own tuning.
225hp and 315ft lb torque.
later
Jeremy
Old 11-19-2004, 01:32 AM
thats nice, but an average '87tpi motor has more like 150,000miles.
Old 11-19-2004, 01:37 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Is that 240hp at the crank? So factor in ~18% driveline loss too.
Old 11-19-2004, 01:39 AM
good point..i didn't even remember drivetrain loss!
Old 11-19-2004, 09:12 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The Stock 87 350 TPI was rated at 225 HP at the crank and with a Auto 20/22% drivetrain loss you would have about 177 RWHP.
Without changing the Cam I don't see very much improvement over those Stock bunbers.
Old 11-19-2004, 12:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
full bolt-ons
like intake, heads, 1.6 rockers, CAI, full exhaust i would think you can get 240-250rwhp easy. Thats 300-312 horses on motor with 20%loss. your cam will be holding you back from there.
like a stealth ram with AFR 195's and longtubes with free flowing exhaust. If the tune is real good, should make some good power if the motor is good condition internally and didnt lose any compression over the years.
now, the fun part. do all the above and add nitrous 125-150 shot and see what happens. could get 400hp or more but who knows how long internals will last under that abuse. LOL
Old 11-19-2004, 01:56 PM
DJP87Z28's Avatar
For the Mods suggested in the above Post by Orr89RoZ to the Stock 350 TPI, I would just go ahead and change the Cam and get the same results easier and cheaper.
Old 11-19-2004, 02:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
true, just a cam swap on 350 TPI would yield good results. probly equal to my previous post. good point, and ofcourse if you go as far as intake and heads, your gonna get a cam as well unless your after some kinda record or something with stock shortblock. LOL
Old 11-19-2004, 02:19 PM
Car: 96 impala
Transmission: 4L60e
I have 200,000 thousand miles on my motor. The motor is running really strong because I cruise most of the time ,but The only time I would actually beat the crap out of the motor is when I do highway roll on's. I had the car on the dyno machine and it pulled 206 rwhp and 306 ft of torque. I have a custom cold air intake, x-pipe, 58mm Throttle Body, and 3.73 gears. The numbers that I am seeing from you guys scares me a little bit because I thought these motors would have put out a lot more horsepower than 240 rwhp.
Old 11-19-2004, 02:27 PM
DJP87Z28's Avatar
All numbers from the Factory are at the Crank and are not RWHP. the quoted 240 was tops for a 350TPI in 89 model and its at the crank.
Old 11-19-2004, 02:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah, TPI intake is the thing that holds back HP production. lots of restrictions in the airbox, intake/runners, and exhaust. Replace all that and you will see good gains on the 350+ motors for sure. TPI was a 305 intake and doesnt flow enough to support lots of hp since it only makes power to 4500rpms.
you may only see like 20rwhp from alot of bolt ons, but look at the torque output. thats what you get from TPI is torque. They love it and so do I. LOL
and that 89 350 power numbers were for the dual cat converter cars which probly made abit less than the dual cat speed density 90-92 cars.
Old 11-19-2004, 04:21 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Originally posted by 3.8TransAM
91 GTA 50k miles
I do my own tuning.
later
Jeremy
Wow those are some impressive stock RWHP numbers
Thats what like 270/370 at the the crank? Can i borrow that Prom?
Old 11-20-2004, 11:13 AM
kevinz85's Avatar
Car: 1987 GTA
Transmission: A4
I thought the 90-92 made 245 from the factory.
Old 11-20-2004, 04:37 PM
nick418's Avatar
Engine: L98, Hemi 6.2
true it is.. But on the Firebird L98s they made 5-10 less hp then the 245 hp Camaro due to the intake design
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
B_Dubya
08-26-2015 05:09 PM
kah992
08-19-2015 02:55 PM
wruiz
08-13-2015 09:07 PM
Quick Reply: How much rear wheel horsepower on a 87 350 TPI?
