holley rebuild
Old 10-31-2004, 07:35 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
holley rebuild
When i bought my camaro 2 yrs ago it had a holley 4160(1850) on it. It is the cheap rebuilt one and i added a electronic choke. I always had problems with the carb and then the motor died one day due to lack of oil pressure. I tore apart the carb and just recently..."bolted" it back together had tight. Rather than buying a new carb for my new motor, do you guys think that if I rebuilt the carb it would work alright. This is my first experience with holleys and i wasnt impressed. I know they are good carbs but could something be wrong with it besides gaskets or powervalve or jets. Should i give this rebuild a go or not?
Old 11-01-2004, 09:37 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Personally I'd trash it, but I've always hated carbs without center hung floats. What kind of new motor are you going to put in? Get a carb for it.
Old 11-01-2004, 12:32 PM
Car: 83 Camaro
Transmission: th350
but isnt there a float bowl type conversion kit that basically turns it into a DP with vacumm secondaries.
what kind of carb would you guys recommend for a mild 355 with a 2500 stall converter, th350, and 3.42 gearing..keep in mind...cheap is good for a high school student. I do not want to spend 500 on a carb
also those road demon jrs. are about the equivalent of what i already have...the 4160 series correct?
Old 11-01-2004, 01:06 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Just get the Holley rebuilt properly by a shop that knows their business. It should work fine once dialed in.
Edelbrock Performer carbs are about the cheapest if you want a new carb.
Do you have a square bore or a spread bore intake manifold? If the latter, you could get a QJet and forget about those other fussy carbs that don't give decent mileage.
Old 11-01-2004, 01:17 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The cheapest thing to do would be for you to rebuild the carb you already have. 600 CFM will feed a 355 up to 5800 RPMs - and that's assuming 100% volumetric efficiency, which is rarely achieved.
You didn't define what you want to maximize with the car. That's important. If you want best 1/4 mile performance, that's a different answer than what will give best gas mileage; and if money spent needs to be minimized, that's still a different answer.
Old 11-02-2004, 12:32 PM
Car: 83 Camaro
Transmission: th350
i would like performance but once again money does matter so I was looking at remanufactored carbs if i go new. How hard is it to rebuild the 4160 carburator?
Old 11-03-2004, 02:05 PM
five7kid's Avatar
Engine: LS1/LQ4
Pretty simple. Have a can of real carb cleaner to dip & soak the parts in after disassembly, compressed air to blow out passages after the soaking, and follow the directions in the kit.
Old 11-05-2004, 08:58 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Those are just about the easiest carbs to rebuild on the planet.
I've done holley 4160s, quads, and edelbrock (carter), and the holleys are the easiest. The only problem is to get them in tune. That is a b!tch.
Old 11-06-2004, 02:20 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Buy a good book or two on Holley's, HP series are good, then learn to do it yourself. One piece of advice...always buy genuine Holley rebuild kits, particulary Holley Needles and Seats. #1 parts problem with Holley's is cr*ppy third party Needle and Seats.
MoJoe
Members Camaros
31
10-06-2021 06:38 PM
NZKnight
10-15-2015 02:47 PM
thekurlyone
09-30-2015 12:54 PM
3.8TransAM
09-27-2015 08:37 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: holley rebuild
