Is my power window motor going out???
Old 05-23-2001, 09:08 PM
AaronRS305's Avatar
Today, when I pushed the switch for the passenger side power window to go up, the window went up about 3 inches, then stopped. I turned the car off, and then back on again and pushed the switch, and it went up another inch or so and then stopped. After that, it wouldnt go up. Then just now, i went out and started my car and it went up and down all the way perfectly fine.
Is my power window motor, or switch is going out? What is neccessary to change the motor, or switch?
1992 Camaro RS L03
Old 05-23-2001, 09:37 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Motor is going out.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old 05-23-2001, 10:04 PM
AaronRS305's Avatar
Damn. Do you know how much a new motor costs, and what it will take to replace it?
Old 05-23-2001, 10:12 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
New ones from GM are about $100.00
I would never install a used one or a rebuilt. Had too many problems with them.
They are a little tricky to do, but easy. I think there is a tech article on this board on how to do it.
We charge $135.00 + parts to do it at my shop.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old 05-23-2001, 11:52 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
I would check the switch though, I know I have a bad switch and it does the same thing, well, let me elaborate a little more, if I "play" with the switch I can get the window up I got real good at hitting the switch "just right" though so I can usually get it up w/o a hitch. I assume when it wouldn't go up for you, you played w/ it a a little right? If not, try that, replacing that motor is a B*TCH!!! (Or at least the curses about the &%^$ &*%$^&* 8&%$&*$*^& 976%&(%6 power window motor coming from a friend sure made it sound like it was a PITA
Good luck
Old 05-24-2001, 11:55 AM
Pukka's Avatar
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Ive just fixed the same problem last fall.
Sounds like your window motor is going bad...rule out a bad switch by just switching the wire/switch connections between both windows...if the problem stays on the same window then the switch is good.
Before you replace the motor, remove the interior door trim and examine the gear/tracks on the window guides for defects.
You do not have to remove the window in order to replace the motor, but I HIGHLY recommend you do so. Everything inside the door is held together with rivets which can be removed using simple tools. The only trick is to be careful when separating the motor from the gear since it is spring loaded. The only problem during installation is deciding whether to use rivets or bolts. I couldn't figure out how to get bolts and nuts in the small spaces required for proper installation. With rivets you cannot buy a rivet gun big enough for the job. I would up getting it riveted at a glass shop for the cost of a 6-pack or beer. Hope this helps
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old 05-25-2001, 12:18 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Pukka: We have a rivet gun for those rivets...each handle is about 2 1/2 feet long It works great.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old 05-25-2001, 08:00 AM
Pukka's Avatar
It must be nice when you can get your hands on industrial tools .
Also NAPA sells new window motors for about $75
Old 05-25-2001, 10:12 PM
Vader's Avatar
Aaron,
You might want to try this first:
Power Window Motor.pdf
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old 05-27-2001, 12:14 AM
Corry's Avatar
Car: 1987 Trans Am
Yes! Another of vader's pdf collection! My power windows work fine now, but....I'm grabbing the pdf
1992 Trans Am
05-10-2023 07:19 PM
BRoss99
12-07-2020 06:50 PM
Vintageracer
01-10-2020 05:33 PM
neekolzun
08-24-2015 04:59 PM
stalkier
08-13-2015 12:59 PM
Quick Reply: Is my power window motor going out???
