Metal/or aftermarket heater control valve?
Old 10-05-2004, 11:02 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Anyone ever seen an aftermarkert unit to replace this piece of plastic crap. I am plumbing the car with braided hoses and Earls fittings and would like to find out if there is anything availiable that has threaded provisions (NPT ports)
Thank you for any help
Dean
Old 10-05-2004, 11:41 PM
25THRSS's Avatar
just ditch it
Old 10-06-2004, 03:31 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
I happen to have put a brand new r134 system on this car and live in hot and sunny So. Calif.
That is not an option I care for.
Old 10-06-2004, 02:26 PM
25THRSS's Avatar
You won't notice any difference. I removed mine to clean up the engine bay and when you have the heater in the off position you feel no heat. Early third gens didn't even have the valve from the factory. If not, suit yourself, but I am not aware of any metal valves.
Old 10-06-2004, 02:57 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
25THRSS is right, removing it causes no adverse effects. You have no heat coming from the vents when it's off and you get heat when you turn it on. Deleting the heater valve just allows coolant to flow through the heater core at all times (I know it sounds bad but it's not, cars have been made that way for years and years from the factory, heater valves are not required). But, it's your decision, not ours, of course .
I have never seen any kind of replacement for a heater valve that isn't plastic and factory designed, but, who knows, they may be out there.
Old 11-05-2007, 12:30 PM
Gmfirebird89's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 V8 TBI
Axle/Gears: 3.23 10 Bolt
Re: Metal/or aftermarket heater control valve?
i have a 89 firebird, and i just broke that stupid plastic heater valve, (nice GM) its ugly and its in the way. i have been ready some threads about it but i just want to make sure, i live in new york where is 95 degrees one day and snowing the next, so i want good heat, if i remove the valve will it hurt anything, and if i i bypass it i know that there will be coolant running into the heater core permently, with the heat turned off will i still be getting heat, and what is the best way to bypass it, i currently have a TBI setup, stock. any ideas.
Old 11-05-2007, 01:08 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
So the search function does work. Egads!
I did a lot of research on this a little while ago, and this is one of if not the best thread.
Edit: This board's link system is broken right now.
Code:
https://www.thirdgen.org/forums/tech-general-engine/222605-what-heater-valve-delete.html
Old 11-18-2007, 10:16 AM
frirebird952's Avatar
Car: 86 ta ws6 silver and gun metal
Engine: 305 fi lb9 eng code f
Transmission: 700 r4 with shift kit
Axle/Gears: lim slip not sure gears
if you are worried about leaving it on all the time go to lowes get a water valve they not as big as stock valve easy to hide that way you can control the water manual the cost about 3.00 to 5.00 dollars i did mine 92 formula it works just fine have not done my 86 yet but if it gives prob i will
1992 Trans Am
05-10-2023 07:19 PM
NORTz89
05-20-2020 03:51 PM
The_Phoenix
02-04-2016 07:10 AM
lakeffect2
08-23-2015 08:44 AM
Quick Reply: Metal/or aftermarket heater control valve?
