Making my AIR pump into a supercharger...
Old 10-05-2004, 12:51 AM
ssnova69's Avatar
Car: 1987 camaro z28
Engine: 305 tpi
What do you think?
Old 10-05-2004, 05:32 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
it would be like pissin on a fire, wont work. Not enought volume.
Old 10-05-2004, 08:10 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ok, well first to build any kind of pressure, we have to seal off all outside air from the motor, so it gets all its air from the pump.
now the pump is small, and moves only a tiny bit of air.
so it chokes the engine. alot.
theres a reason real superchargers are BIG. engines use ALOT of air.
early buicks came with smog pumps more then twice the size of ours. spinning them alot faster then stock lets you push out just enough air to see about 2-4 PSI on a 3.5hp briggs and stratton gokart motor.
just for refrence.
Old 10-06-2004, 08:19 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
I agree. It's not worth the hassle.
Old 10-06-2004, 11:14 PM
zapo's Avatar
Car: 88 Mustang
Engine: 7.7L (473 ci) EFI
Transmission: C6 3 speed auto.
I always wanted to try that..
On my lawnmower, and even there it might take 2 pumps to match the air flow of a 5hp brgs. But man would I cut grass.
LOL
Old 10-07-2004, 02:29 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
http://www.richmondlabs.com/Automoti...argerPost.html
Old 10-07-2004, 08:17 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
ugh. i hate when people who are full of **** start giving advice on the internet.
take a 12v tire inflator air compressor.
block off the end of the hose.
run it.
OOOH! over 60PSI?! why that'll drive the motor.
WORNG. we know it wont. it doesnt even move enough air to inflate the tire quickly.
theres VOLUME and pressure. the pump may be able to produce the pressure, but its not moving enough volume to help the motor.
ah well...
on the bright side, most of the people who think up this crap arnt ambitous enough to do it... athough, it is pretty funny when they try:
Attached Thumbnails Making my AIR pump into a supercharger...-snorkel-side_01.jpg
Old 10-07-2004, 09:51 AM
vladicore's Avatar
Car: 67 camaro ( project )
Engine: 6.7 408 n a snail
Transmission: 4l80 - stalled
Axle/Gears: 3.25 - narrowd tci kit 9 inch
hey thats a cool trick fans in the intake shrouding! never seen that befor. does it work out well?
Old 10-07-2004, 09:56 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
well lets see.
first, a fan of that type is INCAPABLE of making boost. even when deadheading.
second, thoes fans flow less air then the engine draws.
third, because the engine draws more air past them then the fans turn, the fans are spun WAAAY over speed. eventually the fins break off where they are sucked into the motor.
so no. it doesnt work well.
its the perfect example of another BAD IDEA.
Old 10-09-2004, 07:32 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
pretty funny tho...
Old 10-11-2004, 10:23 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
All this reminds of those chintzy *** eletric superchargers. Only $350 for a quote "dyno proven 3-5 horsepower at WOT". What a JOKE!!
Talk about some funny S**T!!!
Has anybody else seen um'?
~Max
Old 10-12-2004, 01:20 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
A guy I went to school with successfully had a electric leaf blower acting as a supercharger but it was on a little 4cly car but he said the leaf blower could blow air up to 50mph I thought it was BS until I seen it and road in it and it was a noticable differance
Old 10-13-2004, 08:56 PM
MerF's Avatar
Car: '88 IROC convertible
Engine: Freakish 305 TPI
Transmission: Dying 700r4
Axle/Gears: LT1 rear
There's a VW beetle doing just this somewhere in VA. Our local board showed it in action, freakin' hilarious.
Old 10-19-2004, 05:10 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Did you read the entire page?
We attached one of these to a friend's son's
go-cart engine (Briggs & Stratton) and the power increase
was very impressive,-- the kid decided he'd like even more
power, and changed to a larger primary pulley. I'm not sure
if it was the extra compression or detonation, but it
didn't run very long after that before the complete cylinder
assembly separated and exploded off the engine block (no
kidding!),-- kind of reminded me of pictures I've seen of
Blown(up) top fuel drag engines.
I don't see any reason that wouldn't work on an engine that size.
Or did you ***-u-me they were talking about an engine in a car?
92camaroJoe
07-29-2023 07:57 PM
mcquigg
08-13-2015 02:26 PM
92camaroJoe
08-13-2015 06:07 AM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: Making my AIR pump into a supercharger...
