new 5.3L w/ carb intake
Old 09-29-2004, 09:46 PM
jake_91_rs's Avatar
Car: 1991 RS Camaro
Transmission: 5sp
does anyone know what intake it would need to put a carb on a newer 5.3L out of a newer GM truck? would the GM Performance Parts LT1/ Gen 2 4bbl intake work or would it be a diff. one......anyone know power levels of this?
Old 09-29-2004, 11:00 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Re: new 5.3L w/ carb intake
The 5.3 truck motor is based off the LS1...nothing from previous motors will work on it...maybe the intake bolts will work though..
Edelbrock makes a kit for the LS1..it includes the intake MSD LS1 specifc ignition box and the harness to fire the distributorless ignition
Old 09-30-2004, 05:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
5.3 is LS1 based? I dunno about that.... cuz people use Vortec heads off those motors on Gen 1 SBC engine dont they?
I thought the 5.3 was just a stroked 305.
Old 09-30-2004, 05:53 PM
Tom 400 CFI's Avatar
Car: '92 Corvette
Transmission: ZF6
Axle/Gears: 3.45
It's LSx based.
Old 09-30-2004, 05:59 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I have the 5.3 in my 2000 half ton truck and it is LS based. It is listed at 285hp.
Old 09-30-2004, 07:35 PM
ljnowell's Avatar
I have been waiting for someone to use that carb setup on an LS motor. I think it will rock. I have also heard of people putting the heads from 5.3L onto the 6.0 block (I think its those two), supposedly gives a nice compression boost. Cant wait for someone to build a LS-based Frankenstein.
Old 09-30-2004, 10:15 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I saw the intake/msd ignition setup in paceparts' magazine. Looks interesting...and would definetly make the swap easier. However its probably expensive....there was no price yet.
Old 10-01-2004, 10:14 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i think popular hotrodding was the rag whos done it already...they tested an LS1 motor with the truck intake, LS1 intake, LS6 intake, the FAST intake and the carbed intake.....all were done on a stock motor and the carb intake was down 4 ponies at most to the fast intake...and up as much as 20 ft pounds down low
just an FYI...the 5.3 truck intake actually flows more then the LS1 intake
Old 10-01-2004, 10:22 AM
ljnowell's Avatar
Nice, I have thought alot about doing that for my next engine. I called around the local yards, and if you dont want the computer, trans, or harness, just the complete ready to install engine, they only run about 550-750. add 800 for the edelbrock setup, some various odds and ends, and I think there is a good budget go fast motor.
neilb
01-16-2016 07:42 PM
customblackbird
10-01-2015 04:30 PM
Thridgen60
01-08-2011 11:53 AM
Blinn79
07-29-2010 08:27 PM
86IROC-z28
06-03-2008 10:54 PM
Quick Reply: new 5.3L w/ carb intake
