Lucas Oil Stabilizer
Old 09-09-2004, 12:14 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I want to say this just so no one has the same thing happen to them that happened to me.
I used some Lucas Oil Stabilizer in an oil change last weekend. Now I have no oil pressure and possibly a spun bearing(s) in my 350. Before I used this stuff, the oil pressure was fine and the engine ran pretty well.
I'm advising everyone here: BE CAREFUL USING THIS STUFF AND USE AT YOUR OWN RISK!!
Old 09-09-2004, 11:12 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
There was a post a long time ago I saw on here about a guy who did a test of oil and oil w/ Lucas Stabilizer side by side in a blender type deal. The oil w/ the Lucas foamed up instantly and in a huge fashion, while the plain oil barely foamed at all.
I wouldn't use the stuff in anything I own.
Old 09-10-2004, 04:09 AM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Hmm
I've owned over 25 cars, and with the exception of the 3 I bought new, I dont think there was a single one I didnt put Lucas in.
Makes me kinda wonder whats happening here....
Old 09-10-2004, 10:54 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
http://www.bobistheoilguy.com/images/lucas/lucas.htm
That is the article I read on that site a while back. It does both a gear lube, and a motor oil piece on that link. Pretty interesting. I don't want foam in my oil...
Old 09-10-2004, 11:11 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by Air_Adam
...I recently did a carb/dissy/intake swap on my 350. I changed from a CC carb and distributor and factory manifold to a Holley 4bbl, vac advance HEI, and an Edelbrock intake. I did an oil change at the same time, with some Lucas Oil Stabilizer added.
Just keeping it in context. I don't like the stuff as it also makes it too 'clingy' as well as the other mentioned problems.
Old 09-10-2004, 11:48 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
I agree RD. If its sticking to the rockers and such up top on the motor, then it takes longer to get down to the pump and the crankcase...
Old 09-10-2004, 12:13 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
can someone explain "sea foam"?
Old 09-10-2004, 12:33 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Sea Foam is a oil based engine cleaner. Some guys use it as a fuel system cleaner, some as a topend engine cleaner, i.e. carbon in the combustion chamber, intake runners, etc...
Cleans out all the goodies... I have used it a few times, only thing I didn't like is that I had to change plugs as soon as I used it b/c it fouled out a few.
Old 09-10-2004, 03:56 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Do a search in Gen Tech, you can make your own.
Old 09-10-2004, 09:34 PM
Air_Adam's Avatar
Well, I got my oil pump off today. BOTH of the 'ears' on that the oil pump driveshaft fits into on the pump sheared off. The mechanic who took a look at the pump said it looked like it basically hydro-locked and snapped them both off.
Never again will this stuff go into my engine(s).
I kept the pump as a momento so I'll have pics later.
BTW - turns out there was otherwise no damage to the motor. Got a new pump in it, 5L of real oil, and she runs like a top with great oil pressure.
Old 09-12-2004, 05:10 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
wow I just bought some for my smoking IROC, good thing I found this thread before putting it in. Is it worth it to add any of those 'stop leak' additives in a smoking motor?
I just hate driving a flashy car and ppl seeing it smoke like it's been flogged to death
Old 09-15-2004, 09:42 PM
IHI
IHI's Avatar
Been running Lucas in both my motors for the past 3yrs and no problems at all. Street drive them whenever time allows and beat the dog ***** outta them every weekend pass after pass anfter pass....Never had a problem with oil pressure other than the fact it picked it up 10psi in both motors once they were broke in and I was able to add the Lucas. Just about evey racer I know uses the stuff round here and swear by it.
Were you using the stock oil pump shaft? Not a real "fluke" deal that it broke. Hope you installed a good all steel aftermarket rod when they put it back together. Good thing you had the lucas in the motor otherwise you would've had problems with bearings with no oil circulation
Old 05-09-2005, 07:13 PM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
i found this post and i see there are people on both sides of the fence here ...i used it in a few cars and just noticed when i put it in a few days ago my car feels like it doesnt wanna yank me up like it did...and the lucas killed the stock 305 4bbl. that was in my car 2 days after i put it in it thats why the 350 is in now 2 yrs later.. im gonna drain it
Old 05-09-2005, 08:00 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I've been using it now for 3 years in my 82 z with a 355ci in it. I've had no problems whatsoever in fact it took care of the problems I was having. I have a little blow by, thanks to the machine shop, that isn't bad till you really pull some high rpm's then it would. I started using the Lucas Oil Stabilizer and my oil consumption stopped and the blow by, though still there, is minimal now, has kept me from getting a new short block at least for another year or so. I too wind the motor to anywhere from 5800-6300 rpm and have found no foaming or other problems. I even used their trans product in the automatic of my daily driver which smoothed out the harshness of the shifts and improved its overall performance. Sorry you had the problems, but I too will continue to use their products.
Old 05-10-2005, 06:43 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i will also stand by there products. i've had customers get new life out of their near dead transmissions and i've never had a single complaint from anyone that i've sold it to. i will continue to use it in my motor
Old 05-10-2005, 10:39 AM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Funny thing about oil or fluid additives. Most people buy the stuff because they think that their aged or neglected motor or tranny is about to take a dump, and they want a 10.00 miracle in a bottle. Then when the poor motor or tranny craps out anyway, they blame the additive. Happens all the time.
Old 05-10-2005, 01:13 PM
primo's Avatar
Every time you put an additive in your oil you are changing the original formula that the oil manufacturer spent time and money in R&D. If you feel you need more protection buy a different oil.
Old 05-11-2005, 02:58 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
305 TBI with 110k miles, didn't burn or leak any oil. Hell, still had original paint on the block.
Used Lucas once. Didn't notice a thing.
Used Marvel Mystery Oil once. Didn't notice a thing.
Used Slick 50 once. Didn't notice a thing.
I have seen the tests and heard many testiments, both good and bad and it still feels almost impossible to make an informed decision. Just use a good oil and filter.
Old 05-15-2005, 02:18 AM
r90camarors's Avatar
Engine: LO3;383tpi
Hmmm. I've used the lucas oil stablizer for 3 years now on various vehicles, and have nothing but good things to say. Of course you will lose some hp when using it, the stuff is thicker than honey! It does however, up oil pressure signifigantly, and is a (temporary)cure to an engine's oil consumption.
With that being said, it is a bandade, not a cure, and there is no reason to be running it in a fresh engine
Old 05-17-2005, 10:49 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
i tried a little of it recenly...
my car, used to make a big cloud of smoke at startup and use oil prety rapidly, i added in not even half a bottle of lucas and after a few starts the blue smoke is gone and it has helped the oil burning quite abit. i'm not the biggest fan of the stuff personally, but it works.
Old 05-18-2005, 08:02 AM
Engine: LO3;383tpi
The problem I have with the test conducted in the link a few posts up is that no ratios are given. They do not say how much lucas stabilizer they added, or what % it brings the fomula to.
Old 05-25-2005, 01:41 PM
mars22's Avatar
Car: 83 firebird s/e w/ttops and a/c
Engine: 2.5 iron duke/ tech IV
Transmission: 5 speed
i have used lucas in a dozen cars and it works grat, ticking lifters quit down, the runs smoother,lucas is awsome .
ahell the lucas probably unstuck that bad bearing so he could hear it! and the ratio is 20-25% i use one bottle and the rest
good high mileage oil. and there transmission stuff got reverse and second gear working in my benz! great stuff, i swear by it.
Old 06-06-2005, 05:00 AM
1320 Right Ln.'s Avatar
does it matter whether the lucas stuff is used with synthetic oil? My 92 Z28 has about 6-7000 miles on it with nothing but mobile-1 used once the break in was done. I have a giant bottle of the oil stabalizer but havent' used it yet. I don't think it'll improve the 92 at all since there are currently no oil problems with the motor. My 91 V6 on the other hand, I may test it with cuz it's up there in mileage, although it still gets 60-80 PSI of oil pressure. It's just that i use mobile-1 in both engines, and i'm not sure if mixing the organic based lucas with the synthetic mobile is a good idea.
Old 06-06-2005, 08:57 AM
86NiteRider's Avatar
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I recently changed to synthetic in my 92 and love it. My 92 has 90,000 and runs perfect. I used Lucas in my 88 Regal but I think it was too late to save the engine. I know the engine went south 500 miles later but I didn't blame the Lucas. However since my 92 is running great I will not add anything to the synthetic. Nowin my 86 I am switching to synthetic on the next oil change. I like the synthetic and don't think I need additives to make it better.
Old 06-06-2005, 12:46 PM
mars22's Avatar
they do make synthetic lucas oil treatment.
if your worried about mixing synth and organic
Old 06-07-2005, 09:21 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Lucas, PowerPunch, etc...
They're all the same...
Either way, there are things you do and things you don't do.
I've ALWAYS used PowerPunch (same crap as Lucas but cheaper) in all of my old beatdown cars and it has done some AMAZING stuff.
The 305 in my old T-Bird was literally changing before my very eyes and ears after adding a quart of PowerPunch. The smoke in the exhaust thinned out, it stopped some pretty massive lifter tap, smoothed out the idle and stopped a bit of vibration, and got rid of a couple nasty noises I was hearing down low.
I used it in every oil change since then for that piece of crap car and I'm convinced that it's the only thing that got me another 3000 miles out of that heap.
It did my little 4 banger 86 Nova a great deal of good also, and quieted that motor down alot, even though it didn't seem to run any different. It DID quiet it down on startup though, which was a big worry for me since it was pretty loud under the hood when you first cracked her open early in the morning. That thing had 265,000 miles on it when I added the stuff, it caught fire at 270,000 miles due to bad electrical and burned up though, so I don't have much of a progress report on that, lol.
I put it in my Camaro and it didn't make the slightest bit of difference except for cutting back on the startup puff of smoke (which was already pretty minimal since it runs so good) but I'll put it in next oil change anyways, just because the motor is still sitting at a bone stock 135K miles.
My brother bought an 85 Firebird with nobody-knows-how-many-miles on it ( the 99,999 odo has been rolled, probably at least twice with how the car looks, lol) the other day and it SMOKE LIKE ALL HELL on startup and when you stomped on it, plus it had a real bad tick.
A little Powerpunch real quick cleaned that up ALOT.
Oil additives are for high mileage motors with worn parts and growing tolerances on the moving parts... Not for brand new motors or even cars that seem to run perfect before that.
If you add water to a plant that isn't thirsty, the damn thing dies 75% of the time.
Old 06-07-2005, 09:22 PM
Car: 92 RS
Engine: a slow one
I meant the 302 in my old T-Bird... All you damn Z-28 guys got my numbers all scrambled up... lol
Old 06-11-2005, 11:51 AM
bjordan's Avatar
Car: 1984 Trans Am
Engine: L69
My 166k L69 has startup smoking blues, and I'm thinking about using a stabilizer until I can get to the valve guide seals. But frothing aside, how is that theoretically better/worse than using thicker oil?
Old 06-27-2005, 08:55 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
i only have one thing to say
THERE IS NO MECHANIC IN A CAN
Old 06-27-2005, 10:22 PM
DanTheMan_smlk's Avatar
i use Restore, works like a charm, i swear u will notice your engine improve after 10-15 miles
http://www.restoreusa.com/
u can get it almost anywhere...ive never changed my oil without it.
Old 06-27-2005, 10:37 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
I use Lucas in my car
I also have built many diesel truck engines for rigs and I use Lucas instead of assembly lube never had a problem
just my experience
Old 07-17-2005, 12:05 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Clingy=drag, among other things. Physics doesn't change for anyone.
Old 07-17-2005, 12:15 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Wait till you open up your motor. Yeck!!
Old 07-17-2005, 10:27 PM
get over it
Old 07-18-2005, 07:49 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
How in the hell did this post get drudged up from the archives?!?!
I love how people fall for the ole Mystery Oil gags. Just like back in the west where people bought whiskey and opium b/c it had wonderful tendencies to heal. Thats right folks step right up and buy this mystery healer... only cost you hard earned money for nothing.
1) Red Devil is right. The more the stuff clings the more it drags causing decline in hp etc. Physics doesn't lie.
2) The way the stuff clings, it does not actually fix problems, or solve issues. It just masks them. Ticking lifter... well the crap is so thick and clingy that while yes, the lifter isn't ticking anymore, but it didn't actually fix anything. Problem is still there...
3) Like I posted last year on this post. Go research the stuff on the oil sites. The stuff Foams. Great thats what you want in your oil is air pockets.
And why in the world do you need Restore every oil change DanTheMan_smlk? If you need that stuff to get the most out of your car more than likely its time for a rebuild buddy.
You can like our opinions or you don't have to. Really I don't give a crap, but don't be so closed minded b/c your uncallibrated butt dyno lies to you every time you change your oil!!! If you need to put this stuff in the car for it to run right... maybe other things are needed besides this "mystery" cure...
Old 07-18-2005, 02:39 PM
i do what i want...im 19
im not rebuilding, i have 80k on the engine. You dont know about this, have u done studies on it?
Old 07-18-2005, 11:45 PM
Engine: LO3;383tpi
But there are no mix numbers on that site. I may be wrong, but show me where they actually state the mix ratio.....
Sure the stuff may foam up on its own or on a crazy mix of 50/50, but if you use the proper mix, the "anti foam" agents in the oil will keep the stabilizer from foaming.
Shoot, I may not have the nice motorized gear set up that site used, but I do have a better much much more sophisticated set up.... it's called a dipstick. Oh yeah, and the complicated task of removing a valve cover Funny, no foam on my dipstick and everything is flowing nicely up top.....and I use lucas.....
Further more, IT IS A BANDADE!!!! But you know what?,it does keep my engine from burning the oil it used to, and for the extra $5 per oil change I can definetely live with that until I swap engines. Hmmm let me see...my "mystery cure" for $5 or hundreds of dollars of work to a 305....Yeah, I'll stick with lucas and spend my money on my 383.
Oh, and for those who are complaining about the viscosity robbing power......I really think loosing 5hp do to drag should be the least of your concerns if you have a knock, tick, or smoke...
Old 07-19-2005, 09:29 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
I barely had 90k when I started my 355 on the TA. I was 19 at the time... Ended completing the swap w/ about 115k and was 22. It takes time. Have I done studies personally... No. I had/have other things to work on like the degree I just finished or various other activities. Do I need to do studies myself. Not really when I can sit and read and see what other REPUTABLE people have already researched.
If you have a knock tick or smoke the first thing you need to be worried about is getting from point A to point B w/o breaking down. That is my point. People look to a $6 bottle of some mixture to fix a problem that is more than just a bottle of crap to fix problem.
Old 07-19-2005, 09:31 PM
Engine: LO3;383tpi
Wow.
That is exactly what I said....
Listen. It is a bandade. But not everyone can afford to drop hundreds of dollars on their vehicles the minute a problem arises. $6 is much more feasable for a lot of people until they can save the money to do the job right.
Better yet, $6 allows you to slow/temperarily help the problem and save up for performance parts or what ever the case is.
You better believe I will invest my time and money into my 383, not the 305. It is pointless to double spend, and time is valuable.
Old 07-19-2005, 11:30 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
oil additives
I have used regular oil 10w30 on my 80 pontiac bonniville
89 celica gts 90 corolla and 86 camaro 350sbc..
Got over 200,000 with regular oil changes.
Ill change the oil every 1000 miles if Im taking short trips
everyday in the city. Theres continuous stop and go
traffic as soon as the oil gets dark its gone...thats all I every did.
oil and filter...just dont beat the **** out of your engine.
remember slick 50 ?
everyone is out to make a buck..
theres a sucker born every minute..
Old 07-20-2005, 05:20 AM
Engine: LO3;383tpi
hmmm....considering some of our cars are older than the driver's and have had multiple owners, it's kinda hard to say that. Further more, it's obvious that you have never used a stabilizer, so what grounds do you have to judge it?
everyone is out to make a buck..theres a sucker born every minute..
You know, I had somebody tell me the same thing about POR-15. I guess we are suckers for using that too? I think not.
Old 07-20-2005, 11:10 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
I put some lucas in with my last oil change when i replaced my sending unit because it was dead. Well no I have no pressure at idle. Maybe its the lucas to blame.... Maybe its time for another oil change already.
Old 07-21-2005, 01:20 AM
Poncho Villa's Avatar
Car: Badass 1991 Firebird
Engine: Screamin' 305 TBI
Axle/Gears: 2.73, 3.42's waiting to go in!
Oil pressure gauges can be dodgy---check your dipstick when you fill up. Anyway, my .02---I have found some oil additives to be helpful, eg. the "motor honey" variety, like Lucas, Valvoline High Mileage Treatment, etc, although the best of those, in my opinion, is Hyperlube Racing Formula--used to be called Hilton's Hyperlube back in the day, and it is very slippery stuff.
My oil has never looked milky or foamy, and the motor is definitely smoother with Hyperlube (same idea as Lucas, but different formula). So for those sold on Lucas, I'd give Hyperlube a try. Of course, as stated above, a new motor doesn't need it, but an older motor can use a bit o' honey between them bearin's. My motor doesn't smoke, leak, or tick, I just switched to more viscosity because I'm assuming a motor with over 100,000 miles could use some added cushioning beyond the recommended 5W30. Why wait 'till she smokes to give her a stouter oil? Whatever you do though, do NOT use Mrs. Butterworth's in the crankcase, even though it's thick and buttery.
As for stuff like Restore, and Slick 50, there's no evidence that it doesn't work, and lots of people swear by it--However, an additive which uses solids in solution, ie. Teflon, or the "microballs" or whatever in Restore, should be used sparingly to avoid buildup of weird stuff in your motor. They even recommend waiting thousands of miles between uses--50,000 for Slick 50, and I think Restore is good for something like 5,000 miles.
Old 07-25-2005, 05:22 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
amsoil is the best stuff I've ever seen, I know this guy who is an amsoil rep, he drives an '87 suburban, when it was bought from the dealer back in '87, the oil was immediately changed to amsoil, and never changed ever again. the truck now has 270k miles on it, and no internal motor problems. that stuff is phenominal.
Old 08-03-2005, 07:41 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
i recently used a bottle of this STP stuff on my car, was thick as honey and took like 5 min for the little bottle to drain... I put it in because i thought, what the hell? i dont feel like workin on my 305 anymore than i have and it couldnt hurt me none if this changed nothing, foaming is scary though, and wonder if this stp crap will foam because if it does ill drain it right away. car has 104k miles btw
Old 08-12-2005, 06:36 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Kinda off topic but i recently used a bottle of lucas tranmission fix in my 75 K-10 pickup (350/TH350) and it completely fried 2nd 3rd and reverse. So now i have a badass mudding truck that wont shift out of first gear and cant back out of a parking space.
Worked fine before. Now i have to wrestle a 150lb transfer case and a 200lb tranny to do a rebuild. Thanks a lot lucas....
Old 08-14-2005, 09:51 PM
Repzard's Avatar
Car: 86 Z28
Engine: TPI 305
Im not one to judge oil aditives
But one thing I can say is changing your oil every 3000 mile is the key to keeping your engine running great and clean
ive been using castol syntec blend oil in my 2001 chevy S10(Daily Driver) sense day one and my opinion it is better than adding any aditive to your oil you get the best of both worlds syn/conven
i think the Lucas stuff is good to hide a problem...that for sure but most cars today take 5/30 oil smaller jornals so i dont think its a good idea to add Lucas
For the people that use Lucus and other products like it
why dont you just add 20/50 or 30 to your oil cause its like doing the same thing and youll save money too..
Just a thought
**Chevy Let Camaro's Live**
Old 09-15-2005, 04:28 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Old 09-15-2005, 04:36 PM
Sorry to bring this one back , but I gotta chime in on my tests with the mystery oil crap.
My motor had 121000 miles when i bought it, and I never did a swap before so I went into reading about mystery oils.
My motor smoked bad at startup and it was eating oil a bit.
So here is what I did and what happened.
1. Lucas (the brand we are talking about).
-- I put it in after I did the rebuild of the whole top of my engine.
I noticed that my engine ran hotter, and my power went down.
my oil consumption also went down.
2. Engine restorer.
-- I put this sucker in as soon as I bought my car. It almost stoped the serious smoking, and my car ran like I just got some life put into it.
NOTE: I took the engine apart after 3cans of restorer in there,
and the baby looked clean. Later I came to find out that the previous owner put in all kinds of different oil in there and basically clogged the passages. Engine restorer helped with that immensly.
3. Straigh up oil, mobil on 7500 long life one.
-- I am using this one currently. My preassure is defently higher, and my car ran cool for about 600 miles after I put it in. Now, my car runs rather hot with 170 thermo, and a new cooling system. It might be related to something else, but thats what am getting. Also, my oil consumption has subsided quite a bit, but I am still adding a quart of oil ever 1800-2000 miles. The engine has very good compression by the way, and my heads have been re-built
So far this is what am getting from mystery oil.
I hope this helps.
Old 09-16-2005, 07:30 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
lol thats great, I have to buy some now to do random tests on it.
Quick Reply: Lucas Oil Stabilizer
