approx. $$ to replace a radiator support?
Old 09-04-2004, 09:53 AM
Phil89GTA's Avatar
Car: 89 GTA
Engine: 350 tpi
I just replaced the fenders and nose on my 89 and i'm having a hell of a time getting the driver side panels to align even close to correct and I'm not very picky about these things...it's pretty ugly.
I knew the radiator support was tweaked a bit by the previous owner, but i'm starting to realize it's actually far from good and it might be worthwhile to replace the whole support and do the job right the first time.
Can someone guesstimate what this should cost? I'm guessing it can't be much more then 4 hours labor for a professional but that's really just a shot in the dark.
Old 09-04-2004, 10:19 AM
LUVmy92's Avatar
Car: Camaro
Coming from an estimator at a body shop (sitting next to me) painted and all around $800
Old 09-04-2004, 01:48 PM
Phil89GTA's Avatar
Car: 89 GTA
Engine: 350 tpi
Much appreciated!
Now i just gotta buddy up with a body guy so i can get it cheaper
Thanks again
Old 09-07-2004, 03:42 PM
85silverz28's Avatar
Car: 1988 iroc z
Engine: 5.7 liter
Axle/Gears: 2.77
If u plan on getting the core support from gm good luck. Most of it was discontinued. But there may be some pieces floating around. If not u may be able to get it after market.
Old 09-07-2004, 03:46 PM
DakotaSLT's Avatar
Or just go to one of the 1,275,945,726 thirdgens in a junkyard, drill out the spot welds and weld it in to your car. Total cost maybe 50 bucks + labor. Hell if you look long enough you might be able to find one already the right color for your car.
Old 09-07-2004, 07:13 PM
Phil89GTA's Avatar
Car: 89 GTA
Engine: 350 tpi
well i saw Crash and Rust had them for $50 or so but i'm not sure how much work that would need to fit nice.
and yes, there are a few billion f-bodys in the yards i could tear into if need be.
The body guy is a friend and he's going to give me an estimate this weekend....he might even know of a donor car. I'll be sure to let you guys know how it works out.
Old 09-09-2004, 10:13 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
the panels are cheap, but to line them up is where the $$ is. i was going to replace minedue to an accident from a previous owner. gonna be 500 labor to make a new one fit perfect..... for the 30$$ part i passed. you cant see the damage with everything installed anyway.
have fun.
Old 09-10-2004, 04:25 PM
BLACK TRANS AM's Avatar
Car: 1984 TRANS AM
Engine: 350 gm crate engine
Take it to a bodyshop to have a bodyman look at it. If you're not picky, you can have it straightened on the frame machine. I am a bodyman and I usually get paid about 3-4 hours to straighten core supports. It usually only takes 1 hour. shops usually charge about 14 hours for that to be changed. that includes everything except for recharging the A/C. If you have sidesway, it will have to go on a frame rack no mater what. Maybe you could take a come-a-long and tie it to a tree for free. can't say without seeing it. P.S. I'm a bodyman. check out: http://members.cardomain.com/black84transam
Old 09-10-2004, 06:31 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
i used a polaris ranger and a toe strap to straighten mine out and it actualy cam out well...
i had my buddy give the atv light amounts of gas till it pulled it out to ware i wanted it couldnt of been easyer.:lala:
now i just have to soem how buy all the new parts to go on the car
Old 09-15-2004, 06:36 PM
Phil89GTA's Avatar
Car: 89 GTA
Engine: 350 tpi
Well the guy came by and pretty much showed me how far to tear it down and what to ask for if i'm calling junkies. He's going to show me where the spot welds are, how to pull the old support off and show me how to get the new one in.
Apparently the plan is to just zip screw in the support a bit, get the fenders and nose on...align everything up nice and then put a few welds in. Disassemble and finish tack welding the new support in.
He's a body guy by trade, but it's nice to see even when he's helping out a buddy on the side that he wants to do it right. Doesn't seem like it's going to cost me much but i'm going to guess we'll figure that afterwards. If it looks real nice, i won't mind dropping a little coin as much.
for the record i did consider a porta-power, trees, BFH's, and even large trees...but I've never done body work like this and the whole idea is to get better right?
If i get my digital camera working again, i'll post some progress pics somewhere
1992 Trans Am
05-10-2023 07:19 PM
Reddeath210
10-06-2015 08:20 AM
Cripley
08-17-2015 03:35 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
Quick Reply: approx. $$ to replace a radiator support?
