What to use to bond plastic to metal
Old 08-07-2004, 11:32 PM
RSFreak's Avatar
Transmission: TH700R4
What is the best substance to use to bond plastic to metal? Something that will create a strong permanent bond.
Old 08-07-2004, 11:34 PM
THEGENERAL's Avatar
sheet metal screw.....
Old 08-07-2004, 11:56 PM
lonniep01's Avatar
Car: 88" CAMARO
i have used jb weld several times .this stuff really works.
Old 08-08-2004, 12:26 AM
3WRBOOO's Avatar
Car: 91 Camaro RS?
Engine: 04 vortec 5.3, F.A.S.T ls1 intake
Transmission: th350 stage2, 4.11 12 bolt rear end, aluminum drive shaft
kitty hair
Old 08-08-2004, 10:00 AM
THEGENERAL's Avatar
yeah i think fiberglassing it on would probably work
Old 08-08-2004, 02:46 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
you might want to try rivets. Good Luck with what your doing.
Old 08-08-2004, 02:47 PM
Dirtbik3r's Avatar
BTW, What exactly is a JB weld?
Old 08-08-2004, 04:32 PM
ede
ede's Avatar
reguardless of what you're doing i'd sure look at soem mechanical means of doing it, along with a bonding agent.
Old 08-08-2004, 10:21 PM
gusman's Avatar
Car: 87 Firebird - Blue - Work in progress
Engine: 305 / 4bbl / No mods - yet.
You can try using a 2-part epoxy. Most are also sandable if you want/need a clean finish.
Old 08-08-2004, 11:23 PM
RSFreak's Avatar
JB Weld is a two part epoxy, right?
Not sure exactly what I'm doing yet, just getting ideas.
Old 08-08-2004, 11:48 PM
lonniep01's Avatar
Car: 88" CAMARO
yes jb weld is a 2 part epoxy.good stuff,if you want it to hold jb weld it
Old 08-09-2004, 12:18 AM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
zippys and duct tape!!! works all the time!
haha jokin......
Old 08-09-2004, 12:51 AM
A 9 Year Wait's Avatar
Car: 1989 IROC-Z 305 TPI
Yes JB weld will pretty much bond anything together, when I was kid, a buddy of mine and I used to JB weld coins to the sidewalk outside his house...Funny when the darn things wouldn't come off for the people that noticed them walking by. I'll have to give him a call and find out if there are any still stuck the concrete..lol
Old 08-09-2004, 10:45 AM
THEGENERAL's Avatar
haha jokin......
forgot about duct tape ....its good up to 200mph right???....j/k
Old 08-09-2004, 05:43 PM
spade's Avatar
yea scotch tape wouldnt be strong.... i figured duct tape it fixes everything!! :lala:
Old 08-14-2004, 03:29 AM
83 Crossfire TA's Avatar
I’ve used mechanical fastners + JB weld + gorilla hair to bond a scoop into a hood before… it looked good for a while till it cracked around the edges. Of course, I did drive the car through a split rail fence, that may have had something to do with it (I was never sure when exactly it started cracking, but would like to do another hood that way so I wish I knew)
I suspect that if I was going to try it again I’d probably do it a little different. JB weld, then a layer of ‘glass/resin to make for a solid piece over the seam, then something like bondo glass and bondo to blend it out.
Old 08-15-2004, 12:11 AM
jocww's Avatar
Car: 84z, 65 elcamino
Transmission: t5 m21
Axle/Gears: 373s 411s
take a block of plastic and melt it with a pencil torch and let its set in the crevice or between the 2 compounds and that would hold it and you could sand it too.
Old 08-19-2004, 10:02 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Axle/Gears: 3.70
The auto body guys are using this new stuff now that I can't think of the name of. But if you go to the auto paint store they will sell it to you. Just explain to them what you want. This is the stuff that is so strong that you can glue metal to metal and if you pull it apart the metal will tear instead of the seam that was glued. I have a friend in the body shop business that uses it to put in quarter panels instead of welding it all the way around. Saves time and doesn't warp the metal like a welder will do. This will bond any material to any material from what I understand.
Old 08-27-2004, 02:39 PM
custom85's Avatar
Car: 1985 camaro
Engine: mpfi 2.8 v6 hopefully soon to be 350
94-6sp i would really like to know what exactly that stuff is ive never heard of it but already have a million uses for it in my head if it works
Old 08-27-2004, 05:43 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
i have been reading up articles on this subject for my cowl scoop project and it seems the best results come from bare metal, 2 layers of fiberglass, then the plastic part, put another layer on the edge of the part and the hood, then bondo it smooth. granted it still might crack but that is the best method i have researched.
Old 08-27-2004, 09:48 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Axle/Gears: 3.70
I'll ask what the name of it is as soon as I talk to my friend and I'll post the name.
Old 09-07-2004, 09:58 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Actually, it's good up to 1000mph, believe it or not
I would also like to know what that "new" stuff is. I think our cars would benefit greatly if the seams from the front bumper and ground effects to the fender were eliminated. Just my opinion but I think it'd give it a more sleek look.
Old 09-08-2004, 09:42 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Axle/Gears: 3.70
Duramax and Durabond...one is PPG and the other is Dupont Brand. I finally asked my friend tonight.
Old 09-23-2004, 10:04 PM
cwalsh's Avatar
Car: 2004 Corvette
use fusor part number 108. It is made to bond metal to all kinds of things and is crash tested and approved by GM
MrPackstin
10-25-2017 08:09 PM
Night rider327
02-25-2016 09:50 AM
bigjay89gta
10-15-2015 08:04 AM
Numbah-1
10-02-2015 08:27 AM
sjorgens
10-01-2015 07:54 PM
Quick Reply: What to use to bond plastic to metal
