lt4 hot cam supercharged
Old 08-06-2004, 02:05 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
is the lt4 hot cam any good for forced air? as in like a supecharger?
thanks
Old 08-06-2004, 02:31 PM
vvv90's Avatar
Car: '92 and '73 Vettes
Engine: Procharged LT1 and 454BB
Transmission: ZF6 and Slushbox
Re: lt4 hot cam supercharged
thanks
A lot of people have supercharged hot cams successfully, but personally I would go with a custom dual pattern cam with more exhaust lift an duration and more lsa, ~114 for blown apps is normal.
Old 08-06-2004, 11:52 PM
TexasLT1's Avatar
Car: '92 RS
If you are on a budget and already have the Hotcam, then sure, just take into accound the lobe sep. If you are looking for a new cam, stay away from the Hotcam. It's designed on its own to increase cylinder pressure, something you don't want when you are going forced induction.
toronto formula
11-10-2015 06:17 AM
anesthes
08-24-2015 08:32 AM
80s Poncho
08-19-2015 06:45 PM
1988iroc350tpi
08-14-2015 07:52 PM
anesthes
08-08-2015 09:37 PM
Quick Reply: lt4 hot cam supercharged
