How To Convert From TBI To Carb
Old 08-05-2004, 10:17 PM
88CAM305's Avatar
Car: 1988 Chevorlet Camaro
Transmission: 700-r4
I currently have a 305 With a TBI injection system, i want to change it over to a carb, but i dont exactly know what i need. I am going to put a new intake manifold on it, probably an edelbrock performer series, and i think i need to get a new distributor. I have also heard i need a new fuel pump, but what else do i need to do??? i am planning on gutting the emissions crap too, and the ecu will be removed probably also,, but that is as far as i have gone???? any suggestions?????
Old 08-09-2004, 11:43 AM
Supporter/Moderator
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
This should help
Swapping EFI to carb
Old 08-09-2004, 06:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Im moving this to the carb board, they should be able to tell you all youll want to know about converting over to a carb.
Old 08-09-2004, 07:47 PM
88CAM305's Avatar
Thanks, im pretty new to this site,, always good to have some help
Old 08-09-2004, 11:02 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
That article pretty much covers everything. I would leave the ECM in just in case you have VATS though. It wont be controlling anything, the only problem youll have is the check engine light will stay on, but you can just pull the bulb for that. also I would keep in the intake electric pump and just use a bypass style regulator. Thats the way I am running it on my mild 350 and it works great. Its a pretty easy swap I did it all in two days(would have been one, but I ran into a complication). Good Luck.
MustangBeater20
10-29-2022 09:20 PM
pimp2303
07-27-2017 02:03 PM
theshackle
03-05-2017 06:37 PM
MustangBeater20
Carburetors
08-21-2015 02:42 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: How To Convert From TBI To Carb
