Keeping water out of cowl hood
Old 07-23-2004, 02:38 PM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Transmission: T-5 w/ Hurst Shifter
has anyone come up with a way to run the cowl on the power bulge hood open all the time yet keep water out when it rains at the same time? i tried a piece of sheet metal across the opening that only blocked about the bottm 1/3 to 1/2 to try and block water from going in, but that didn't work at all. so i put the plate back on for now, at least until i can make something that will actually work. if you guys have pictures of your set up, i'd really appreciate seeing them. thanks in advance.
Old 07-23-2004, 03:09 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
i was thinking about this myself i was thinking of making a lille hindged mount with a peice big enough for to cover the hole. then having a little motor that controls this that you can flip the switch. alto of fabbing but worth it im my mind
Old 07-23-2004, 03:17 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what would water hurt?
think about it.
the engine itself should be sealed.
everything underhood must be able to take the spray of when you drive in the rain.
water isnt pouring into the carb.
the only thing you have to do is make a couple drain holes in your carb to hood seal pan, if you have one.
Old 07-23-2004, 03:20 PM
Car: 86 z28
yes but where i live man when it rains it rains hard and there is alot of water everywhere like street flood and stuff so if i was to hit that with a ss hood my air filter atop my carb would be soaked thus sucking water into it and i think this is what this guy is talking about. this is something i too would like to figure out before i buy my new hood
Old 07-23-2004, 03:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
run a cotton/oil filter like a K&N or one of the knockoff ones, and dont worry about it.
Old 07-23-2004, 04:20 PM
Car: 1992 Firebird
i'm just worried because the water that gets in falls almost directly onto the distributor. i opened the hood and the top of the air cleaner was holding water and the distributor was wet as well.
Old 07-23-2004, 04:26 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Do you have the water catcher?
Old 07-23-2004, 04:29 PM
Car: 1992 Firebird
no, i don't. i've never seen that before? i just got the hood a few days ago after my stock one got smashed up. where would i look to find one of those?
Old 07-23-2004, 04:30 PM
Agent13's Avatar
Engine: LG4
Any 82-84 T/A with the functional hood should have it.
Old 07-23-2004, 04:42 PM
Car: 1992 Firebird
it looks like it just dumps that water down onto the strut tower and the other end in closed. is that right? i'm guessing it also has a slight slant to the driver's side. it doesn't look to hard to fab up, maybe i'll try it this weekend. thanks for the pic.
Street Lethal
04-30-2019 12:14 PM
cougar20th
08-27-2015 08:04 AM
LittleFranks
08-20-2015 03:55 PM
Dialed_In
08-20-2015 01:45 PM
ElPaleterro85
08-13-2015 03:49 PM
Quick Reply: Keeping water out of cowl hood
