3 relay firebird headlight.. .experts only
Old 07-17-2004, 03:49 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
okay... here's the story... orginally, my car's headlight doors only flipped down, and not up, after replacing the relays for each door i got the driver side to go up and down!!! . however, my passenger side still only goes down. the isolation relay (the one near the radiator) was not replaced. could this be the cause of the passenger side still being faulty, or could it be something else.. thanks
Old 07-17-2004, 04:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's possible but did you also check the fusible links that go to each of the two actuator relays. They are located in the headlight wire bundle near the left side of the radiator.
Old 07-17-2004, 04:47 PM
Dingley's Avatar
Engine: LG4 305
the fusible links are connected and good. but i need to know if the isolation relay needs to be replaced, or if the wires going to the headlight relay (that i already replaced) are bad.
Old 07-17-2004, 04:48 PM
Dingley's Avatar
Engine: LG4 305
....like i said tho.. the driver side is working perfectly!
Old 07-18-2004, 03:55 PM
Dingley's Avatar
Engine: LG4 305
any help... does the isolation relay need to be replaced!?
Old 07-18-2004, 05:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here, maybe this will help you.
Old 07-18-2004, 05:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old 07-19-2004, 05:23 PM
BirdofFireBOB's Avatar
Car: 88formulatp1
Engine: 5.0
Transmission: 5
there are two blue wires coming out of the iso relay, one has a white trace.Each blue wire goes straight to a headlite door motor.When your headlite switch on the dash is off, both of those blue wires should have +12V-They provide the +juice for the door motor down circuit. There are two seperate sets of contacts in the iso relay- one for each door down circuit,, switched on by one coil.. I've seen one set of contacts go bad, causing the symptoms you are having..You can prove the defect by cutting into the insulation of the blue wires and checking for +12V on both wires..With the dash headlite switch shut off..
Old 08-04-2004, 08:18 PM
Dingley's Avatar
Engine: LG4 305
the isolation relay is GOOD. the headlight relays are GOOD. what is the fusible link? can someone show me a picture? thanks.....
Old 08-04-2004, 09:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, it is these two little thingies!!!!!
Old 08-04-2004, 09:23 PM
Dingley's Avatar
Engine: LG4 305
now where would those be located in the car?
BigNg's Avatar
Car: 84, 86
Engine: 84 w/V-6, 86 w/305 V-8
Transmission: both auto
Trickster:
WHAT THE HELL WOULD WE DO WITHOUT YOU?
Fantastic info, exactly what info I needed too!
MOST EXTREME BONUS KARMA GOING YOUR WAY!
B
Old 08-04-2004, 09:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Dingley,
Just follow the treasure map, "X" marks the spot in the headlight wire harness near the left side of the radiator shroud.
Old 08-10-2004, 07:15 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
Where can I get a Isolation Relay ???
as a matter of fact were can I get the other to also, besides the dealer and junk yard.
Old 08-16-2004, 09:47 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what years are all the info above for ? for an 82 too, or no ? when was it changed from three relays to two relays in these cars ? or was it three wire to two wire ?
thanks
Old 08-16-2004, 10:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
thanks
Here is the schematic for the headlight doors for a 1982 firebird. As you can see on the first schematic posted and this one, there is very little difference between the two for the most part. The most noticable difference is the wiring at the headlight dimmer switch. Have fun!!!!!!!
Attached Thumbnails 3 relay firebird headlight.. .experts only-headlight-doors-10001.gif
Old 08-16-2004, 10:31 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
good deal
thanks
gonna need all this when i find 87-up motors for the 82, currently are both removed from car and harnesses hanging
so,,
:O
Old 03-25-2009, 12:59 AM
gabc's Avatar
Re: 3 relay firebird headlight.. .experts only
hey im having the same problem with my 87 firebrid exept both headlighgst dont go up but they go down...by all of this im assuming its the isolation relay..does anyone knw where its located thanks
Old 07-21-2010, 07:24 PM
paulfirebird's Avatar
I have a very odd problem of a similar nature. 1997 Firebird. Recently the headlights were requiring that I switch them off and then back on a couple time to get the lights up and on. Keep in mind I have no motor run-on or grinding occuring. Anyway, now the problem is much worse. If the car is off, the headlights operate perfectly. However, if I start the car the headlights come on and I cannot shut them off. Occasionally, they will stay down, but the lights are on in the closed position. I have checked all fuses and cleaned all available connectors - including on the isolation relay. I cannot locate the fusible links, the main headlight module, or the actuator relays. Is ANYONE familiar with this problem? I am eight hours into this and frustrated as hell.
RazorN8
01-07-2022 11:44 AM
Glowsock
08-02-2020 07:36 PM
Papaginos
09-27-2015 03:29 PM
Bert87
08-23-2015 03:50 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: 3 relay firebird headlight.. .experts only
