pete jackson gear drive and knock sensor are they compatible?
Old 06-02-2004, 10:41 PM
jake's Avatar
Newbie with tpi compatibility questions. I was wondering if anyone has ran a gear drive with a knock sensor?
Old 06-02-2004, 11:21 PM
Raiden's Avatar
nope
Old 06-02-2004, 11:30 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yes they are. The standard Pete Jackson gear drive is not compatible with your knock sensor. What you need to get is the "quite" gear drive for factory roller cams. If you really want one here is what you want:
Jegs:
782-350-91C SB-Chevy with Factory Roller Cam (excluding LT1) $152.99
Summit:
PJJ-350-91C Small Chevy: 305, 350 with factory roller cam (exc. 1992-up LT1), "quiet " gear drive $152.95
There are plenty of people on these boards running these drives.
Old 06-02-2004, 11:32 PM
jake's Avatar
I am not running a roller cam.
Old 06-03-2004, 01:53 AM
Guest
Guest
Posts: n/a
The only people that will say you cant are those who havent tried it. They're re-quoting from what they've read elsewhere.
IIRC Tim Burgess is actually using a noisy drive. I'm running a 'quiet' drive, if you can call it that. Its still loud, IMO. The knock sensor on my car doesnt care about the PJ, it only has a fit when there's actual detonation going on.
TPI? From a Team G and 750 carb? I think you're going to be disappointed.
jklein337
09-19-2018 06:23 PM
db057
08-22-2015 08:17 PM
mizz0313
08-12-2015 06:45 AM
gwade12
08-08-2015 08:17 AM
Quick Reply: pete jackson gear drive and knock sensor are they compatible?
